Go to Post Too often we like to forget that it takes an insane amount of hard work to even have a chance to overcome raw talent. - Paul Copioli [more]
Unread 14-01-2012, 10:23
mGt31097 mGt31097 is offline
Crazy Yelling Person
AKA: Matt Terry
FRC #1716 (Redbird Robotics)
Team Role: Mascot
mGt31097 is an unknown quantity at this point
Re: Do you "have" to use a shooter?
There are no rules saying that you have to use a shooter. But it is really helpful, and your alliance members would get ticked off at you for not being able to score a lot.
Unread 14-01-2012, 10:44
aRobotDragon aRobotDragon is offline
FRC #1504
aRobotDragon is an unknown quantity at this point
no but if you use a dumper you cant make the 3 point basket and there is still a 4 or so inch gap between you dumping part and the basket also you can be blocked because there are only 2 or three places you can dump from
Unread 14-01-2012, 11:02
RahatAhmed RahatAhmed is offline
FRC #4300 (The Lion Kings)
RahatAhmed is an unknown quantity at this point
So you wouldn't be able to just drive right up to the basket and drop your balls down a chute into the second basket?
Unread 14-01-2012, 11:24
Queengeek Queengeek is offline
FRC #0346
Queengeek is an unknown quantity at this point
I don't think you have to use a shooter. If you can use something to force/push the balls out with some speed wouldn't it make up for those 4 or so inches your lobber couldn't reach.
Unread 14-01-2012, 13:36
Can you attempt a dunk? Yes. In fact, for the 2-pointers, it will definitely work without added propulsion, if you do it right (and possibly are willing to take penalties). For the 1-point basket, some propulsion will be needed in the horizontal direction; for the 3-pointer, vertical and horizontal propulsion will need to be supplied.
Is it possible to supply that propulsion? Yes. See 2008's hurdling designs for ideas. Is it going to be easy? Not necessarily.
