Go to Post Don't start celebrating yet. I haven't a clue if we can get this working. - Kevin Watson [more]
  #31   Spotlight this post!
Unread 12-01-2012, 14:33
Brandon Holley's Avatar
Re: Hoops
Originally Posted by Mr. Pockets View Post
To anyone who has actually gotten ahold of one of baskets in question: would using a standard regulation basketball net give substantially performance results?
Its a tough question to answer. FIRST has spent time to specify not only a different spring for the hoop, but a different net as well. I recall reading somewhere in the drawings that the additions would be fine for practice, but the real field would be using the substitutions theyve implemented. A regulation size basketball hoop is a regulation size basketball hoop. Functionally it SHOULD be the same, but theres really no guarantees unless you got them side by side.
It seems that changing out the springs and netting on whatever hoop you get would be worthwhile simply to make sure you are designing to what the field will offer.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #32   Spotlight this post!
Unread 12-01-2012, 15:18
tlivingd's Avatar
tlivingd tlivingd is offline
FRC #4095
tlivingd will become famous soon enough
Re: Hoops
Thanks for the Walmart tip! Ordered 3 today. Would be nice if at least one was in the KOP.
Edit. Most home use nets are very cheap. I have a hunch that the nets provided are closer to an NBA model where it's a heavier nylon cord. Unfortunately our midwest kickoff was the team field, Not the FIRST field.
Nate
Mentor Team #4095 Team RoXI
Student Team #13 BioBeast
  #33   Spotlight this post!
Unread 12-01-2012, 15:25
tlivingd's Avatar
FRC #4095
Re: Hoops
Sorry to spam this thread.
for those who haven't seen the game specific drawings, the notes below are on drawing GE-12013.
"Notes:
1. Remove stock net. It will not be used for competitions. It if fine for practice, but the
length may not be compatible for the rest of the field components.
2. Remove stock spring from the backboard and replace with the specified spring from
McMaster. Once again, the stock spring is probably good enough for practice, but the
McMaster spring has more give to it. "
Nate
  #34   Spotlight this post!
Unread 13-01-2012, 02:59
RoboCat2005 RoboCat2005 is offline
AKA: Catlin Level
FRC #3659 (Mighty Patriots)
RoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to all
Re: Hoops
As for practice reason, we talked to our schools basketball coach and got some old rims that were laying around. Although not the "actual" rim, they are regulation and meet the same dimensions so for practice reasons will work. Biggest benefit, did not cost us a thing.
  #35   Spotlight this post!
Unread 13-01-2012, 03:17
Aren Siekmeier's Avatar
on walkabout
Re: Hoops
We've been slowly bringing them in from people who have hoops at home and never use them. It's 4 nuts to undo and you have your hoop, and then plywood makes a fine backboard.
  #36   Spotlight this post!
Unread 13-01-2012, 05:52
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: Hoops
While trying to make your field parts as close to official parts is nice, it really isn't necessary for something like hoops. An 18" hoop is an 18" hoop. If seems to me that if whatever you're working on is so absolutely reliant on a certain spring stiffness in the hoops (hoops that you're never even going to touch), then you'reg going to have trouble no matter what.
Just take a look at the difference between the low cost ramp, and the official ramp. It sure is nice to have that built to spec perfect field, but it really isn't necessary.
  #37   Spotlight this post!
Unread 13-01-2012, 06:00
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
Re: Hoops
Originally Posted by compwiztobe View Post
What rule is this? The fender is there to protect the rims, but there is no rule barring contact with the fender, or even climbing on top of it. Granted, it would be difficult to do, given its height, and probably not worthwhile.
G10 as modified by team update on 1/10.
Robots may not push or react against the top of the Fender.
  #38   Spotlight this post!
Unread 13-01-2012, 23:29
Re: Hoops
The soft springs in the official competition hoops are likely to make the basketballs bounce less when they hit the rim. I suspect it will be easier for them to go in.
  #39   Spotlight this post!
Unread 14-01-2012, 00:33
adengler's Avatar
adengler adengler is offline
Mr. Dengler
AKA: Aaron Dengler
FRC #2090 (Buffnblue)
adengler will become famous soon enough
Re: Hoops
Originally Posted by waialua359 View Post
well we finally ordered 3 of them.
After searching site after site, they were either sold out or an outrageous price with shipping.
It was a whopping $243.xx!
Same for us in Honolulu.... Shipping was $37.00 for each rim!
2090 BuffnBlue | Punahou School | Honolulu, HI
  #40   Spotlight this post!
Unread 14-01-2012, 03:08
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Hoops
In my mind, it either goes in without bending the hoop at all or it's pure luck and we can't change our design to compensate for it. What's the point?
Anyway, wouldn't the springs only kick in if the ball hit the top of the rim, in which case you missed anyway?
  #41   Spotlight this post!
Unread 14-01-2012, 03:44
Lavapicker's Avatar
Lavapicker Lavapicker is offline
FRC #1056 (Hot Rocks)
Lavapicker is just really niceLavapicker is just really niceLavapicker is just really niceLavapicker is just really nice
Re: Hoops
I found them online at sports authority. For Hawaii teachers, I used the 15% off from my HSTA card. Shipping was still close to $50 but The total was closer to $150 for three. I'm looking forward to replacing my 15 year old rim at home when the season is over.
2003 - Pacific Northwest Regional-Seattle :Quarterfinalist
2004 - Pacific Northwest Regional -Oregon
2007 - Silicon Valley Regional
2007 - Atlanta:Galileo Field (5-2)
2008 - SVR finalist*, Engineering Inspiration Award
2008 - Hawaii semi-finalist, Team Spirit Award
2008 - Atlanta:Archimedes (3-3-1)
2010 - Hawaii regional quarterfinalist
2011 - Hawaii regional finalist, Engineering Inspiration, Innovation in control
2011- St. Louis Galileo Field (7-3) 14th seed, quarterfinalist
2012 - Hawaii Regional Semi-finalist, creativity, industrial design awards
  #42   Spotlight this post!
Unread 14-01-2012, 10:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Hoops
Originally Posted by Taylor View Post
http://www.competitiveedgeproducts.c...il.aspx?ID=305
Buy 4, pay $41.28 each. Free shipping to continental US. Includes net.
Ordered these a while back and have they arrived yesterday. They arrived as Spalding hoops, so they must be the same. They ship in their original boxes separately.
  #43   Spotlight this post!
Unread 14-01-2012, 13:19
CoachSally CoachSally is offline
AKA: Sally Wells
FRC #3711 (Iron Mustangs)
CoachSally is an unknown quantity at this point
Re: Hoops
Big 5 carries Lifetime Slam II Rims at 39.99. I called the closest store which had 2 in stock. They had 2 more by the next day.
