Go to Post Oh geez your using math. I never touched the stuff myself.:o - Koko Ed [more]
Unread 14-01-2012, 10:35
flyvin flyvin is offline
FRC #0095
flyvin is an unknown quantity at this point
Accelerometer Showing All Zeros
I'm trying to get the accelerometer to work using Java, but I'm having some trouble. I'm wiring it with I2C and using the "ADXL345_I2C" class. When I try to print out the x, y, and z values using "getAcceleration()", it just prints out zeros for everything.
I've gone over the wiring a bunch of times and it all looks correct to me. We also checked to voltage on the pins and it seems to change when we shake the accelerometer, so I don't think it's broken. Our java and crio are both up to date (as of today). I've never used I2C before, so there might be something obvious I'm missing. Any help would be appreciated.
Unread 16-01-2012, 13:10
abrightwell abrightwell is offline
Lead Software Engineer
FRC #0342 (Burning Magnetos)
abrightwell is an unknown quantity at this point
Re: Accelerometer Showing All Zeros
We seem to be having the same problem. We will continue to research it, if we resolve it we will report back.
Unread 16-01-2012, 13:17
youxinche95 youxinche95 is offline
AKA: Eugene Che
FRC #0649 (MSET)
youxinche95 is an unknown quantity at this point
Did you wire it correctly? We had the saem problem with our gyro, but it turned out it the pwm was not supposed to be in the digi-sidecar.
Good luck!
Unread 16-01-2012, 19:49
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
You have the wires going to the special pins on the digital sidecar? There are two sets of four, and you want the set closer to the edge.
Unread 17-01-2012, 00:19
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
I know it doesn't add much, but our team had this same problem last year. We followed the diagram as best we could, and even asked on CD. I guess we can look forward to having the same problem this year, too
Unread 17-01-2012, 01:22
ggorsuch ggorsuch is offline
FRC #2471 (Team Mean Machine)
ggorsuch is an unknown quantity at this point
Are you using the flat ribbon db37 cable included in this years KoP, or the previous round one?
Unread 19-01-2012, 13:27
As promised, we resolved it by following ggorsuch's recommendation. Apparently the older round cable doesn't work for this purpose. Also, be sure to follow the directions here to make sure your flat cable is "built" correctly. Again, thanks ggorsuch for your help on this issue.
Unread 19-01-2012, 13:48
It is weird that it doesn't work with the old cable. We had the same problem. It has worked in previous years. It must have to do with the different slot the dio module goes in.
Unread 20-01-2012, 22:00
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
we were following that a week ago and we broke our cable... so do we really need to order another one?
Unread 20-01-2012, 22:29
The sensor manual says
Note: The ADXL345 starts in a power saving mode. You must turn it on by writing 0x08 to POWER_CTL
(0x2D) before it will do anything interesting.
so how would someone go about doing this?
Unread 21-01-2012, 00:03
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
I'm just going off the javadocs, as I've never used accelerometers.
But the "write" method of the I2C class seems useful.
Unread 21-01-2012, 01:17
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Does the built-in ADXL345_I2C class do this automatically when the constructor is called, or do we have to do something else, like use the I2C class?
Attending: MN Duluth Regional
Unread 21-01-2012, 01:37
FRC #1700
It does it for you; take a peak at the ADXL345_I2C source code and you can see it right there.
m_i2c.write(kPowerCtlRegister, kPowerCtl_Measure);
Unread 21-01-2012, 15:45
this is what we are using for the code:
ADXL345_I2C acll= new ADXL345_I2C(2,ADXL345_I2C.DataFormat_Range.k8G);
public void teleopPeriodic()
		hi1 = acll.getAcceleration(ADXL345_I2C.Axes.kX);
		hi2 = acll.getAcceleration(ADXL345_I2C.Axes.kY);
		hi3 = acll.getAcceleration(ADXL345_I2C.Axes.kZ);
                disp(1, "" + hi1 + "                        ");
		disp(2, "" + hi2 + "                        ");
		disp(3, "" + hi3 + "                        ");
disp is a custom method we made to output to the DS LCD
but this gives us just all 0
We also have the accelerometers plugged into the the 2 sets of 4 pins next to the "phone jack".
Unread 21-01-2012, 17:59
You are using more than one accelerometer?
