Go to Post Bottom line - keep your passion for FIRST and don't let others spoil your fun! - Sean Schuff [more]
Unread 14-01-2012, 11:07
Kpown Kpown is offline
FRC #1123
Kpown is an unknown quantity at this point
Question SO...alternative to ramps...
Currently we are thinking of not even trying to do this.
and suggestions?
Join My Minecraft Server:
Hamanchi:
zahillacraft
123
SERVERIP:
5.120.151.126
Play Aiimscape
Aiimscapes(DOT)smfnew(DOT)com
mediafire(DOT)com/?hfixy3uon1da3z3
GO TEAM 1123!
Unread 14-01-2012, 11:13
Andrew Lawrence
Posts: n/a
Re: SO...alternative to ramps...
Use 4 wheels, don't use 2009 wheels, don't have the motors where they can contact the bump.
Unread 14-01-2012, 11:19
b00mhead$h0t b00mhead$h0t is offline
FRC #1123
b00mhead$h0t is an unknown quantity at this point
I would suggest useing 4 wheels......
Also you should make the bumber higher and move the motor and use another motor,and hook up the motor to a battery
Unread 14-01-2012, 11:34
speedbuggy76 speedbuggy76 is offline
Manellis
AKA: Matt Ellis
FRC #0118 (The Robonauts)
speedbuggy76 is a jewel in the roughspeedbuggy76 is a jewel in the roughspeedbuggy76 is a jewel in the rough
I think there are a lot of people who will be going over the barrier. However, I would recommend using more wheels to do so, probably at least 6. This will decrease the amount of space you have between each wheel to 'bottom out' in.
Mentor for Team 118 - The Robonauts
Former mentor of 2415 - The WiredCats
Former member of 1002 - The CircuitRunners
Unread 19-01-2012, 12:44
nhansen14 nhansen14 is offline
AKA: Nolan Hansen
FRC #3467 (Windham Windup)
Team Role: Team Spirit / Cheering
nhansen14 is an unknown quantity at this point
Something my team is in the process of designing is a skid plate. So it's like a slanted piece of metal or some material that would hit the barrier before anything else, lifting the robot up so you can still use smaller wheels to get over. It's an interesting application of a wedge in my opinion.
Unread 19-01-2012, 14:10
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Same with 2410 for the skid plate. We're going with, I believe, 4 wheel wide drivebase and skids before each wheel.
In terms of your pic, add a wheel and power at least 2 of your wheels and chain the others. For your chassis, looks like you would have enough roomto make a six wheel drive. Oh, and use the kit wheels, not lunacy wheels. It'll help with traction.
Academic Student (Forever)
Unread 19-01-2012, 14:15
Chris is me's Avatar
AKA: Pinecone
Doesn't work as well as you'd hope, at least with kit wheels.
Unread 19-01-2012, 16:56
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I would put 6 wheels on there if you're going long over wide, or you're going to have a host of problems with controlling the drive.
Unread 19-01-2012, 18:03
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Mixed bag. The middle wheel helps with respect to turning on the flat floor but it makes crossing the barrier a bit more exciting (read, tippy).
You pays your money and you picks your poison...
Joe J.
Team #88, TJ2
Unread 19-01-2012, 18:08
pfreivald's Avatar
AKA: Patrick Freivald
So the question is, "how can a band saw help me cross the barrier?"
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 19-01-2012, 20:36
ThunderTrain ThunderTrain is offline
AKA: Captain Thunderman
FRC #1511 (Rolling Thunder)
ThunderTrain is an unknown quantity at this point
Thumbs up Re: SO...alternative to ramps...
four wheels can cross the barrier if you allow ffor a skid plate between wheels to prevent it from getting stucck in the middle. also motors should be mounted to the top of the frame.
