Go to Post I'm hoping for a JVN action figure this year! - marshall [more]
Unread 14-01-2012, 11:45
Jengles's Avatar
Jengles Jengles is offline
FRC #4753 (Bexley Lions)
Jengles will become famous soon enough
Classmate E11 help!!!
Was the Windows OS suppose to be pre-installed on the Classmate E11? Our Classmate came with it pre-installed, and when we are trying to run the image software it gives us a error code. We have not been able to use the flash drive that was provided to us.
Unread 14-01-2012, 21:01
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Classmate E11 help!!!
Have you read the instructions?
Unread 14-01-2012, 21:52
techkid86's Avatar
techkid86 techkid86 is offline
Magic Programer
FRC #3044 (0xBE4)
techkid86 is an unknown quantity at this point
our flash drive failed as well. we had to manually install the driver station code. if this is the case for you, there are instructions out there for that. it should be attached to this post. (we just had to do this today as well ^_^)
hope this solves your problem ^_^
"you can build a perfect machine out of imperfect parts" -Urza
