Go to Post my original intention were that the 5 of them were the power rangers, but then i thought of Copioli as the Pink Ranger and laughed... a lot - Mike Schroeder [more]
Unread 13-01-2012, 16:52
nyindojin nyindojin is offline
FRC #3059
nyindojin is an unknown quantity at this point
Help with sample program code
We are entering tank drive sample into our last year cRIO and we get this error message:
Access denied: This target is running a version of Labview Real time that is different than the Real-Time Module software on the host computer. You can verify the version and reinstall the Real-Time software using Measurement and Automation Explorer.
We have formatted the cRIO, installed all updates but still get the error.
Unread 13-01-2012, 17:02
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Re: Help with sample program code
We had the same problem, try to insert the update USB that has the Labview for this year and run it again. This might fix any old software that might be running. This is how we fix this problem. Let CD know if the problem is still now fixed.
"A team back in training !"
Unread 13-01-2012, 21:28
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
You said that you formatted, but did not say if you re-flashed the cRIO to any specific version. If it is still using the image from last year, this will cause issues.
Mike B
Unread 14-01-2012, 11:49
FRC #3059
We did not reflash... just to be safe, is this how you reflash...
http://www.usfirst.org/sites/default...20System_2.pdf
page 16 and 17 of the document from that link, in other words we reformat the cRIO.
Unread 14-01-2012, 11:55
Yes, you should use that procedure to load image v43 onto your cRIO.
