Go to Post you must understand when wearing that FIRST Volunteer shirt, you personally & directly represent FIRST, and you do the best job for FIRST as an organization, that you can in performing that job....Period. - cglrcng [more]
Unread 14-01-2012, 12:04
Re: Kinect WPI library error 7
Originally Posted by 1997dodo View Post
we're attempting to run the VIs on a computer because we don't want to set up the cRIOs
That won't work. The vast majority of the WPILib VIs will not run targeted to the computer without some (and for many heavy) modification. You're going to need to set up your cRIO if you want to test out the WPILib VIs.
Unread 14-01-2012, 12:10
1997dodo 1997dodo is offline
FRC #0449
1997dodo is an unknown quantity at this point
I'm willing to go through heavy modification... problem is, I'm not experienced enough to know how. The rest of the team is busy prototyping to stop and set up a cRIO for us to play with. so, i guess we're screwed...
