Go to Post I tried, but our freshmen lost enthusiasm about filing the blocks of aluminum I gave them into Andymark Performance Wheels after only a few hours! - Greg Woelki [more]
Unread 14-01-2012, 12:18
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
BaneBots CIM-U-LATOR Gearbox Issue
Has any one had the issue of mounting a 775 motor to a gearbox when the motor is tightened down it becomes nearly impossible to turm? We got around this by putting the lock washer outside the gearbox. Is this the correct placement of the washer? Should the washer be on the inside of the CIM-U-LATOR? Thanks in advance, and good luck in Rebound Rumble!
2011 Record (11-3-0)
