Go to Post If it's good enough for Star Trek, it's good enough for FRC. :) - KarenH [more]
Unread 13-01-2012, 11:02
usacat6 usacat6 is offline
AKA: Will
FRC #2228 (Cougar Tech)
usacat6 is an unknown quantity at this point
Repeating "waiting for cRIO to reboot"
NetBeans console message “waiting for cRIO to reboot” repeats every few milliseconds even when the robot is functioning.
Java NetbeansIDE 7.1
Java program “SampleProject” from the “Getting started with java for FRC Control System_2 “ document.
cRIO firmware update with the latest code, checked and updated again
Execute the Java run to down load program, ftp completes, “waiting for cRIO to reboot” appears on console
Drive station communication and robot code status indicators go off
Drive station and communication indicators come back on
“waiting for cRIO to reboot” message continues to repeat on the NetBeans console
Robot drives when enabled, code seems to perform as designed.
“waiting for cRIO to reboot” message continues to repeat on the NetBeans console.
Does anyone know why the console keeps getting the “waiting for cRIO to reboot” message? Java code or some other problem?
Unread 13-01-2012, 11:03
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
Re: Repeating "waiting for cRIO to reboot"
When we had this problem in the past, the problem was that the subnet mask on the development computer was not the same as the robot - 255.0.0.0.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 14-01-2012, 11:31
AKA: Will
Checked the subnet mask this morning. Set to 255.0.0.0.
Updated Java this morning, prolem with repeating waiting for cRIO still exists.
Unread 14-01-2012, 12:59
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
We found that just resetting the robot per normal did the trick. Have you tried this?
Otherwise, my team had this problem a few days ago and for the life of me, I can't remember how we fixed it. If you still don't have this solved when (or if) I remember, I'll definitely let you know.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 14-01-2012, 13:29
AKA: Will
Checked all the subnet masks on all the network components. According to the "Getting started with the 2012 Control System_2" the subnet mask on the cRIO is 255.255.255.0. We changed all our network devices to have this subnet mask. Rebooted all devices. The repeating "waiting for cRIO to reboot" still persists.
Unread 14-01-2012, 15:48
Lalaland1125 Lalaland1125 is offline
AKA: Ethan Steinberg
FRC #2429
Lalaland1125 is an unknown quantity at this point
Make sure to use static ip's and set your computer to either 10.xx.xx.5 if you are the classmate or 10.xx.xx.6 if you are other.
We have this problem every time we switch to the DCHP on our router( so we can access the internet).
Unread 20-01-2012, 08:34
AKA: Will
Smile Re: Repeating "waiting for cRIO to reboot"
Last night we implemented the smartdashboard. We are able to send data from the cRIO to the smartdashboard with no issues. We are using the Java command-based robot project with NetBeans 7.1 The “waiting for cRIO to reboot” message persists on the programming computer console.
By the way the programming team is very excited about the command-based robot project. They recognized the benefits of this platform very quickly.
Unread 20-01-2012, 10:18
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
You can always try re-imaging the cRIO if the problem persists.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 26-01-2012, 20:18
AKA: Will
We found the problem. The computers we are using for programming are loaners from a company sponsor. They still have the companies virus protection software loaded. We installed the wireshark network packet analyzer and discovered the cRio trying to communicate using port 6666. The McAfee virus software blocks port 6666. We disabled the On-access scan function and the communication issue was resolved.
