Go to Post When in doubt, ask... don't assume (unless you don't mind wasting time/money). - Bill Gold [more]
Unread 14-01-2012, 12:18
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
BaneBots CIM-U-LATOR Gearbox Issue
Has any one had the issue of mounting a 775 motor to a gearbox when the motor is tightened down it becomes nearly impossible to turm? We got around this by putting the lock washer outside the gearbox. Is this the correct placement of the washer? Should the washer be on the inside of the CIM-U-LATOR? Thanks in advance, and good luck in Rebound Rumble!
2011 Record (11-3-0)
Unread 14-01-2012, 12:43
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
Re: BaneBots CIM-U-LATOR Gearbox Issue
When you tighten one of the cim mounting screws down it might pinch the gear down on the 775. Be careful if you are mounting it to another gear box because that screw can go through to far and into the cim-u-lator box.
Michael
Stampede Robotics Mentor
FRC 2844
2012 Arizona Regional --Judges' Award
2012 Las Vegas Regional -- Regional Winners
2012 Las Vegas Regional-- Coopertition Award
2009 Arizona Regional -- Rookie All Star Award
Unread 14-01-2012, 13:27
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
It sounds like the screws your using to mount the 775 are too long and hitting the windings of the motor.
