Go to Post If we all keep our "secrets" about our robots, the rest of us don't learn as much. - Rick TYler [more]
Unread 09-01-2012, 14:40
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
FRC 2012 Kit of Parts and Field
It's ready!! You can now go to www.autodesk.com/first and download the Kit of Parts, including the FRC 2012 Competition field.
Let me know if you have questions on opening the files or if there are any parts in your kit that are not available as Inventor models.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 09-01-2012, 14:46
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: FRC 2012 Kit of Parts and Field
Is there any way we can get a STEP file of the field?
Unread 09-01-2012, 15:01
Ty,
As per my note on the SW forum, it will be posted in 30 minutes. In the meantime I am sending you the file. Look out for a YouSendIt message.
Phil Dollan
Autodesk Inc.
Unread 09-01-2012, 23:25
Team 3705's Avatar
Team 3705 Team 3705 is offline
FRC #3705
Team 3705 is an unknown quantity at this point
Thanks for the STEP file!
Unread 12-01-2012, 16:31
mryeagle mryeagle is offline
AKA: Jeff Yeagle
FRC #2229 (ROBOSHOP)
mryeagle is an unknown quantity at this point
Frustration with the autodesk supplied kit of parts.
i've downloaded the zipped files from autodesk, unzipped them, I can see assemblies when I preview assemblies within inventor. yet when I attempt to open the assembly file I recieve an error message indicating missing paths!
I teach this every day, I use inventor every day, the path seems correct, and I have the appropriate project file set up.. yet I cannot open assembly files from the downloaded files thanks to unresolved links??
high tech, low down.
http://lh3.ggpht.com/_u-f_SuDRS8E/SjhtxflFZNI/AAAAAAAAArA/wNWwcr2dOWI/s144/DSC00472.JPG
Unread 12-01-2012, 21:23
Cloud_9ine Cloud_9ine is offline
AKA: Derrick Miller
FRC #2022 (Titan Robotics)
Cloud_9ine is an unknown quantity at this point
We are having that same issue.
Unread 12-01-2012, 23:16
Naga1 Naga1 is offline
FRC #0086
Naga1 is an unknown quantity at this point
Exclamation Missing wheel assembly and it's parts
Hi i have found that the drive base kit is missing the entire assembly for the wheel and the parts for that assembly is missing from the source file on the AUTO DESK site. Can anyone report this so we can retrieve those files?
Unread 13-01-2012, 07:35
AKA: Jeff Yeagle
Glad I am not the only one with this issue..
Unread 13-01-2012, 10:59
Alex Richard Alex Richard is offline
Dabbler
FRC #1414 (The International House of Technology (IHOT))
Alex Richard is an unknown quantity at this point
Hey-
If anybody still needs the HiGrip FIRST Wheel CAD, you can get it, as a STEP file, from AndyMark here. To do so, go under "Files and Documents," then download the "6" HiGrip Wheel CAD File (.stp) (right click, save as)". Once that has been done, Autodesk Inventor can open the file, then resave it in the proper format. It won't be the right material/color, but it is the right shape.
Unread 13-01-2012, 11:21
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
When I try to open an assembly/part I get the message "Error in reading RSe stream". I can open the STP file of the Field though.
Unread 13-01-2012, 13:10
Sounds like you are using Autodesk Inventor 2011. The 2012 KOP files cannot be opened in 2011.
Phil Dollan
Autodesk Inc.
Unread 13-01-2012, 13:34
I have checked and reposted the Drive Base Kit on the Kit of Parts.
Also, the wheel is posted as an Autodesk Inventor assembly file under Drive Train.
Let me know ASAP if you have any issues and I can resolve them for you.
Phil Dollan
Autodesk Inc.
Unread 14-01-2012, 07:32
jreuter jreuter is offline
FRC #1073 (Force Team)
jreuter has a spectacular aura aboutjreuter has a spectacular aura about
Really, Inventor 2012 only?
My school decided not to upgrade, and everyone is still on Inventor 2011
What are our options?
Just use 2011 KoP?
Open in 2012 and save as something (STEP files?)
Unread 14-01-2012, 09:17
frank.pendzich's Avatar
frank.pendzich frank.pendzich is offline
Mr.P
AKA: Mr. P
FRC #3011 (RoboWarriors)
frank.pendzich is an unknown quantity at this point
Our school is licensed for Inventor 2010 only. We're unauthorized to install the 2012 version. The kit of parts for this season requires 2012 to open the parts. Can you recommend a way we can get versions of the drawings that will work with our version of the software?
Unread 14-01-2012, 13:43
The Kit Of Parts from 2010 is still available on the Education website. It will resolve most of the needs you have for robot parts. In addition, companies such as AndyMark and VEX are very good at posting STEP files of their parts which can be opened in 2010.
Try this and let me know what, if any major parts you are missing.
Phil Dollan
Autodesk Inc.
