Go to Post Some of the best team captains I've seen have been from rookie teams. - Conor Ryan [more]
Unread 14-01-2012, 12:45
omsahmad's Avatar
omsahmad omsahmad is offline
FRC #1595 (Dragons)
omsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really nice
Jaguar Motor Controller Problem
As I was trying to make the RJ12/DB9 convertor, I was putting the pins in the slots and testing to see if it worked, and on one attempt, all of my brown jaguars stopped flashing. I checked to see if they were still getting power with a multimeter, and they were. The black jaguar is still working, and the PD board is fine. I don't think they all got fried, because it would be too random for seven motor controllers to get fried at the same time. I am using a CAN bus system and when I put a new jaguar at the end, it worked.
Thanks for help,
Omair
Unread 14-01-2012, 12:52
Re: Jaguar Motor Controller Problem
Thanks for help,
Omair
Does your CAN bus have the proper termination resistance at each end?
Unread 14-01-2012, 13:25
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
When you stated they stopped blinking did you mean they are all illuminated or they are all off?
How were you testing to see if it worked?
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 14-01-2012, 14:13
omsahmad's Avatar
FRC #1595 (Dragons)
Yes it does. I added the new jaguar to the end of the CAN bus and put the terminator in that as well, and it worked.
Unread 14-01-2012, 14:18
omsahmad's Avatar
FRC #1595 (Dragons)
They are all off. Like I said to "Ether," I tested by adding another brown jaguar to the end of the line (hooked up to the CAN bus), and it worked.
