Go to Post I wouldn't mind dropping a banana peal or throwing a red turtle shell at other robots, but that's the rules! - SpaceOsc [more]
Unread 10-01-2012, 20:36
usacat6 usacat6 is offline
AKA: Will
FRC #2228 (Cougar Tech)
usacat6 is an unknown quantity at this point
Missing Java Default Code Project
Issue finding the BuiltInDefaultCode Project to test crio firmware and other control components. Follwing the Getting Started guide procedure on page 23 and 24. Have checked the crio firmware version. No issue. Have checked the updates.xml from WPI, the version is correct. Loaded plugin via the url link to WPI. Using netbeans 7.1. Thoughts?
Unread 14-01-2012, 14:35
DaveFrederick's Avatar
DaveFrederick DaveFrederick is offline
FRC #1895
DaveFrederick is a jewel in the roughDaveFrederick is a jewel in the roughDaveFrederick is a jewel in the rough
Re: Missing Java Default Code Project
Do you have the FRC ICON in the tool bar?
I was having problems getting the FRC plugins for 2012 to load into netbeans.
After a great deal of frustation, I figured out that the WPI FRC Plugins for JAVA Netbeans require a host with 768 MB of memory. Our old laptops have 512 Mb. The problem was compounded that Netbeans does not present any error that it could not load the plugins.
I ordered more memory for the laptops.
We need a new version of the document "Getting_Started_with_Java_for_FRC.pdf" with this information. The current document is from 2010.
Dave Frederick
Unread 28-01-2012, 19:00
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
I am having the same issue with locating default code that doesn't exist. I have a copy of it because I used it before the kickoff started. I have re-installed the plugins, but no luck. This is confusing that the codes do not exist in the file location.
Team 1369
Senior
Head Programmer (Java)
Head Electrician
