Go to Post Once you go to your first (FIRST) competition... thats when you fall in love with it. - Jaine Perotti [more]
Unread 11-01-2012, 23:30
swapnil94 swapnil94 is offline
FRC #2935
swapnil94 is an unknown quantity at this point
WPI robotics library for C++
Is there any library like thing for c++ WPI Library which shows me what each code does. Kind of like Java API like this http://docs.oracle.com/javase/1.5.0/docs/api/ .
Unread 14-01-2012, 17:10
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Re: WPI robotics library for C++
If you grab the .chm (windows help) file from
http://firstforge.wpi.edu/sf/go/doc1198?nav=1
After downloading, be sure to right-click/properties on it and click "Unblock" in the properties page or it will show no output on the right side when you run it.
Then double-click on it and you'll have the full doxygen output from the WPI lib fully browsable and searchable. Same as java.
bob
Unread 14-01-2012, 17:16
The doxygen is also installed to C:\Windriver\docs\extensions\frc (never had to use the unblock trick so I'm guessing you don't need it for the local copy?)
Unread 14-01-2012, 17:23
Da' Mentor Man
FRC #1967
Right - unfortunately, the 2012 file is only available online. The 2011 file is in the location locally you mentioned. If you want the update, you'll have to deal with the 'unblock' issue. I email'ed Kevin (the author) earlier today and he clarified this with me and worked like a charm.
bob
Unread 14-01-2012, 17:29
I have an updated copy in my docs folder on a fresh install. Perhaps it's not overwritten properly by the Workbench update?
I just opened the Workbench update with 7-zip and it's definitely in there. Regardless, the steps Bob posted appear to work if you don't have an updated copy in your docs folder.
Unread 15-01-2012, 22:38
FRC #2935
Thanks! I found that file before but I couldn't open it.
And the one in program files seems to updated as it has kinect classes.
Unread 16-01-2012, 17:34
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
I have run doxygen on the sources myself and they're posted on my github page:
http://rbmj.github.com/612-code/doc/html/annotated.html
Unread 18-01-2012, 09:13
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
You are my hero for the CHM link. I've been looking for actual API docs for days now. The tutorials and such are helpful for cut-and-paste code but this is needed to really make the code fly. Thanks much!!
-Mike
