Go to Post Why do FIRSTers think we're better? ...because we hold values like honesty, integrity, and intelligence dear... - Redneck [more]
Unread 07-01-2012, 17:49
2012 KoP motor part numbers
The 2012 KoP lists motor part numbers
AM802-001A
am-9012
am-9014
I was assuming these were AndyMark part numbers, but when I searched the AndyMark web site, these part numbers were not recognized (see attachments).
What up?
Name:	KoP motor Part Numbers (am).png
ID:	11284  Click image for larger version
ID:	11286  Click image for larger version
ID:	11287  Click image for larger version
Unread 07-01-2012, 17:56
Re: 2012 KoP motor part numbers
I think am-9012 and 9014 should be am-0912 and 0914
http://www.andymark.com/product-p/am-0912.htm
http://www.andymark.com/product-p/am-0914.htm
The am-0255 page references AM802-001A
Unread 07-01-2012, 18:20
Thanks Joe.
I'm updating my motor calculator for the 2012 KoP motors.
Unread 07-01-2012, 19:52
The AndyMark web site lists the following specs for the PG71 (am-0914) motor:
84 rpm & 1.3 amps @ 12V no load
6.8 ft-lbf & 11.3 amps @ 11.6V stall
Extrapolating the stall from 11.6V to 12V would give:
6.8*(12/11.6) ft-lbf & 11.3*(12/11.6) amps @ 12V stall
Assuming max power occurs at half speed and half torque would give:
half speed = 84/2 = 42 rpm
half torque = 6.8*(12/11.6)/2 = 3.52 ft-lbf = 675.3 oz-in
max watts = (42 rmp)*(675.3 oz-in)/1352.3 = 21 watts
The web site says max power is 130 watts (see attachment).
Somebody please check my math?
Name:	PG71 AM-0914 gearmotor.png
Unread 07-01-2012, 20:08
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I think your math is correct.
Peak mechanical power (at half of free speed and half of stall torque) is about 21W.
Electrical power would be about 70W under those conditions.
I don't have access to my team's motors right now, but after the Monday meeting I will take them to the lab, and try report dynamometer test results on Tuesday or Wednesday.
Edit: It appears that this gearmotor is aimed at replacing the old-favorite Globe transfer case gearmotor, which had more than twice the stall torque and about the same free-speed. That motor could develop about 80W peak mechanical power, if I recall correctly.
Richard Wallace
since 2003
Last edited by Richard Wallace : 07-01-2012 at 20:18. Reason: added Globe motor reference
Unread 07-01-2012, 20:12
fantastic. thanks.
Unread 07-01-2012, 20:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
3.52 lbf-ft * 1.356 N-m/lbf-ft = 4.77 N-m
42 rpm * 0.10472 (rad/s)/rpm = 4.4 rad/s
4.77 * 4.4 = 21-ish.
Your math checks, so I'd guess there's a problem with the specs somewhere. Probably the listed max power. The input power at half torque is about 73W. So at max power it's either 30% efficient, or 178% efficient. I know which side I'm putting my dollar on....
Unread 07-01-2012, 20:19
Thanks Joe.
Done. http://www.chiefdelphi.com/media/papers/2432
Unread 07-01-2012, 23:38
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
This has the maximum power as 18.28 W.
http://www.usfirst.org/sites/default...r%20Info_0.pdf
Unread 09-01-2012, 11:27
On that chart, the AndyMark part number is listed incorrectly.
It should be "am-0914" not "am-9014".
Also, if you go to the AM website for am-0914, you will see that the specs listed there differ greatly from the FRC chart.
Unread 14-01-2012, 18:05
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Does anyone know if the AndyMark PG-71 gearmotor (am-0914) can take a side load?
The Globe gearmotor of similar design could not.
Unread 17-01-2012, 22:29
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Hey, can a Globe motor be used this year? Also, does anyone know where I can get a spec sheet on it? Thanks
