Go to Post It’s impossible to know who’s life you will change forever. Don’t miss an opportunity. I’m an optimist. Have a great season. This is the year. - Rich Kressly [more]
View Poll Results: Long or Wide Base
Long 58 50.00%
Wide 58 50.00%
Voters: 116. You may not vote on this poll
Unread 08-01-2012, 18:43
meebee's Avatar
meebee meebee is offline
FRC #2134
meebee is an unknown quantity at this point
Re: Long vs. Wide Drivebase
Originally Posted by BrendanB View Post
Three wides will fit with 11inches of overhang. If one of those is long you are never balancing.
Doesn't this mean that if the outer bots are 4wd, just the slightest error in driving will send one of the robots toppling over the edge?
This 3 robot balancing act seems to be getting harder and harder...
Unread 08-01-2012, 19:03
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
They don't necessarily have to go single file remember.
Bridge is 48" wide, two relatively thin robots could squeeze next to each other. Or overlap could occur to squeeze a third on.
Unread 08-01-2012, 20:05
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Originally Posted by GBilletdeaux930 View Post
I think you are overestimating how tippy the bridge is. You can be pretty offset and the bridge will still stay "balanced"
http://youtu.be/-AMaqqmoLgQ?t=1m27s
The offset isn't the problem; the amount of space available for turning is. With 2 other robots, even if they're sideways, you'll only have 20 inches or so in which to turn.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 08-01-2012, 20:14
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
You'll literally have no space to turn once the other two robots are on. 3 wide robots, with bumpers, will take up 28X3 inches + 4X3 inches, or 96 inches. The bridge is 88 inches. You get a few extra inches if the wheels of the end bots are right at the edge, but not enough. Someone has to hang off or be way smaller than the max dimensions.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 08-01-2012, 20:47
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
If you want to be picked for elims then go wide. No long robot will get on that bridge with two other robots and balance.
Those are some very bold statements. Have you already tested your bridge theory?
Coming from a team that has been Wide Base more often than not, I've learned that controlling a wide base robot on a field with terrain without tipping over is a considerable challenge. According to one of our mentors, our Aim High robot was driven very carefully (on a field with no terrain besides the ramp) to avoid tipping. Rapid acceleration and deceleration while driving a wide base robot is a recipe for disaster. Drivers used to a standard drop center 6 wheel drive will find that driving wide base is quite different than what they're used to. It obviously can be done, but it's just tougher.
Despite the drawbacks, wide bases do have certain advantages that might be pivotal. The increased area for an accumulator allows drivers a lot more leeway during pickup, regardless of ball control. I can see this reason, coupled with the attractiveness of having a smaller profile on the bridge, driving many teams to build wide base robots; however, I'm expecting that the disparity between Elimination-worthy wide and long bases will favor the latter, due to more teams sticking with what they're comfortable with.
Unread 08-01-2012, 21:19
Joe Schornak's Avatar
Joe Schornak Joe Schornak is offline
No Stranger To Love
FRC #2840 (Blue Tide)
Joe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to behold
My team was initially favoring a wide base over a long base, for the reasons mentioned above. This changed when our prototype shooter bot almost tipped backwards when I lifted its front wheels onto the barrier. Our current design is now a long base with a hybrid mecanum/traction drive to aid in climbing the barrier.
I think that teams are underestimating the difficulty of crossing the barrier. It will be very difficult or impossible to do with 8 inch wheels or smaller, unless you have a way to change your wheel's initial contact point on the barrier. The necessity of large wheels or other chassis shenanigans will reduce the length of the wheelbase and make a wide configuration less advantageous.
1. Acquire Manual
2. Read Manual
3. ???
4. PROFIT!
Visit www.pcdsrobotics.org!
Unread 08-01-2012, 23:09
samholladay's Avatar
samholladay samholladay is offline
FRC #1912
samholladay is an unknown quantity at this point
Our team was wondering if we could climb over the bump/barrier with 6 8" wheels. We were thinking of making a robot that is slightly wide, maybe 28 x 32. In that case we would have some of the advantages of a wide chassis (and would fit on the bridge better), but hopefully it wouldn't be as tippy as a robot that was, say, 28 x 38. Of course, 8" wheels may not be able to get over the barrier, and that will become a big issue for a lot of teams as the build season goes by. If 8" wheels don't work we may have to try something weirder, like 8 6" wheels or something.
Unread 08-01-2012, 23:38
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The reason a wide robot is tippy is because it's only 28" long (maximum), not because it is wide. With 8" wheels you have a 20" long wheelbase maximum, probably considerably less since you probably need some frame to be outside the wheels. It's the short wheelbase that is the issue.
Unread 08-01-2012, 23:39
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Not unless you use a 20 inch wheel.
Unread 14-01-2012, 13:36
KennyLives's Avatar
KennyLives KennyLives is offline
Grand Vizier of Pneumadynes
AKA: Kenneth Prouty
FRC #2122 (Team Tators)
KennyLives is an unknown quantity at this point
Well, longways seems to be much easier to control, especially over the bump. If you want the best of both, you could go with a mechanum drive, if you don't mind being pushed around.
No leaks. Ever.
Unread 14-01-2012, 13:47
rifkinni's Avatar
rifkinni rifkinni is offline
AKA: Nicole Rifkin
FRC #1676 (Pascack Pi-oneers)
rifkinni is an unknown quantity at this point
Our team is still debating the issue. One of the advantages that hasn't been mentioned is that a wide robot can pivot better than a narrow one. It might make things easier for fine-tuning your aim.
Unread 14-01-2012, 13:59
B-Bot's Avatar
B-Bot B-Bot is offline
AKA: Ben
FRC #0768 (Techno warriors)
B-Bot is on a distinguished road
Just make a long robot with mecanum drive so you can get on the ramp the head on way during qualifications and then sideways during finals.
Unread 14-01-2012, 14:08
jblay's Avatar
jblay jblay is online now
Here comes StuyPulse
AKA: Joe Blay
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
The Dean Kamen segway wheelchair (Don't know the actual name off hand) would be ideal for this game
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 14-01-2012, 14:27
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
As I type this, my team is testing a wide chassis prototype. I just watched the thing fly a full 4-5 inches into the air after hitting the hump. Besides for that, it is very unstable and top-heavy. We are all leaning towards the fact that the narrow chassis is a much better choice.
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 14-01-2012, 18:10
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
How far off the ground was your shooter and how heavy was it?
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
