Go to Post I'll toss this out to stir up the pot: if you need double precision floats for your FRC software, you should re-think what you're doing. - Ether [more]
Unread 14-01-2012, 19:28
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: OpenCV with Axis Camera
There is atleast 3 different topics started about that question. Do a search and youll find a ton of information.
How is it possible to get the camera image to OpenCV running on a computer on the same network?
Obtain the MJPEG stream directly from the camera.
I was thinking of a separate socket connection to the robot and have cRIO transmit the AxisCamera data over the network to a server on the computer, and that computer does whatever to it.
sockets. There are rules on the port numbers, however.
706 has a semi working system and are going to be posting a full length tutorial on how to do the obtainment of an MJPEG, filter bad colors, find a rectangle, take those points and fit them to a mathematical model (distance and angle, ray style), rectify that model, apply it in an algorithm, create a socket server and client, and send it back.
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
