Go to Post Build season is the best time of the year. Better than Christmas because the presents are cooler, and better than new years cause you get to stay up later. - burkey_turkey [more]
Unread 14-01-2012, 19:52
ekgordon2 ekgordon2 is offline
FRC #2022
ekgordon2 is an unknown quantity at this point
cRIO, NI Axis Setup Tool, and Axis Camera Manager can't connect to Camera
Like a couple other teams, my team is using WindRiver C++ and are using the following code to connect to the camera:
AxisCamera &camera = AxisCamera::GetInstance("10.20.22.11");
		camera.WriteResolution(AxisCamera::kResolution_640x480);
		camera.WriteCompression(20);
		camera.WriteBrightness(0);
However, we are getting this error at the drive station at startup:
ERROR: S_errno_ECONNREFUSED (0x0000003D): Failed to connect to the camera ...in CreateCameraSocket() in C:/WindRiver/workspace/WPILib/Vision/AxisCameraParams.cpp at line 457
We can ping the camera at the IP address 10.20.22.11, but everything else can't find it. We can't get to a web interface, the setup axis camera utility can't find it (because it is expecting the 192.168.0.90 address), and even a utility downloaded directly from Axis, the Axis Camera Management tool, can't access it.
Is there any way to completely reset the Axis 260 Camera to factory settings and re-set it up?
Thanks in advance.
Unread 14-01-2012, 19:55
Re: cRIO, NI Axis Setup Tool, and Axis Camera Manager can't connect to Camera
Thanks in advance.
The Axis Camera setup describes the process, but basically hold the reset button while applying power. Keep holding it until the lights turn on (I think) then release.
Based on a post by Greg McKaskle in another thread there may be something wrong with the Setup Axis Camera tool, so it's recommended to set up the camera manually for right now.
Unread 15-01-2012, 02:12
FRC #2022
It took a few tries, but this worked. I just set the IP address manually using the web interface. Thanks.
