Go to Post Team spirit is not all about the tools/noise makers. The Tigertrons didn't have any sort of noise makers. Consider other aspects of the award by making signs, mascots, cheers, and how you interact with other teams. - team222badbrad [more]
Unread 14-01-2012, 20:36
Mr.Trips Mr.Trips is offline
FRC #3179
Mr.Trips is an unknown quantity at this point
Unhappy Laptop will not find the robots cRIO
Are laptop will not find the cRIO, we have tried takeing off the firewalls and that didnt work either... help
Unread 14-01-2012, 20:44
B-Robinson B-Robinson is offline
FRC #0343
B-Robinson is an unknown quantity at this point
Thumbs up Re: Laptop will not find the robots cRIO
Check your robot and trace the wire(s) leading to the linksys (or other internet device) until it plugs into the breaker box on your robot. Then make sure you are supplying the correct number of amps. We had the same problem today. The ampage will be displayed on the actual device
-Team 343-
Unread 15-01-2012, 13:30
What program are you running? What is it telling you that makes you think the laptop can't find the cRIO?
How are you connecting your laptop to the cRIO?
How are you powering the cRIO?
Unread 15-01-2012, 13:42
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
make sure you also set your IP properly by putting your team number in the driver station
Unread 15-01-2012, 14:12
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
If you mean that the Driver's Station won't pick up Communication, then you must set your computer's IP to 10.te.am.6, with a subnet of 255.255.255.0.
So, if you were on team 1234, your computer's IP would be 10.12.34.6.
Unread 15-01-2012, 17:15
FRC #3179
Unhappy Re: Laptop will not find the robots cRIO
We do have the correct IP address also we are runneing 2012 lab view, also when have are (programeing) laptop teathered to the robots cRIO and we scan for it, it simply says something on the lines of...cRIO not found or what not, in a sence it doesnt exist.
Unread 15-01-2012, 17:26
FRC #0023 (PNTA)
Rookie Year: 1620
What are you using to 'scan' for it? Are you using the crossover cable?
Unread 16-01-2012, 20:02
FRC #3179
We are waiting for our new cRio to come in but would like to use the old robot for some trial runs. So would this be the problem that the new software will not work with the old crio and power distribution board.
Unread 17-01-2012, 08:04
The HW will work fine once it is imaged to be compatible with the newer programming and communications tools. If you later want to put it back on the old robot, you can decide whether to keep the newer image or put back the older image.
To image it, use the cRIO Imaging tool located in the Tools menu.
Greg McKaskle
Unread 18-01-2012, 12:08
bstewart's Avatar
bstewart bstewart is offline
FRC #3511
bstewart is an unknown quantity at this point
Our*
