Go to Post There are few times I sleep so soundly as I do after an FRC build season and regional. - JamesCH95 [more]
Unread 14-01-2012, 20:59
jo3_sum jo3_sum is offline
jo3_sum is an unknown quantity at this point
Java Motor Control Troubles
My team is having trouble using java. We can't set a regular/not-CAN Jaguar motor controller's speed. It says it can't find the module and port. Are there any simple examples where we can test only 1 motor controller with a joystick? Most of the samples want multiple devices. We are still doing baby steps.
Unread 14-01-2012, 22:31
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
Make sure that you are using module number 1 for the first digital module regardless of what slot it's in. Also, if you upload your code we can take a look.
Brad
Brad Miller
Robotics Resource Center
Unread 14-01-2012, 23:06
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Re: Java Motor Control Troubles
Here ill get you going on a simple code.
first thing under your public class put
Joystick joystick1;
Victor motor1;
Under that line put:
public void robotInit {
joystick1 = new Joystick(1);
motor1 = new Victor(1) // the one can be replaced with any PWM port on sidecar.
NOTE: You will have to import the Victor class and Joystick class. you can do this by adding this above your public class:
import edu.wpi.first.wpilibj.Victor;
After that just simply put this in your operator control
while(isOperatorControl) {
motor1.set(joystick1.getY()); // gets the val from joystick and converts to pwm
Yes i do know that you are using Jaguars not Victors but the coding for the two on pwm is practically the same and should get you going good. I suggest your team looks in to using CAN it has so many nice features.
Unread 16-01-2012, 20:42
Sorry, about being vague in the first post. I was in rush.
It turns out we forgot to move the modules from last year's slots after re-imaging.
Then, we used motor_controller = new MotorController(int slot, int channel) instead of motor_controller = new MotorController( int channel).
The motor moves, now.
