Go to Post Downsides: it's highly toxic and recognized as a carcinogen in CA. Upsides: Basically everything else - lethc [more]
Unread 14-01-2012, 12:31
B-Robinson B-Robinson is offline
FRC #0343
B-Robinson is an unknown quantity at this point
Help how to draw a basketball in Inventor.
How to draw the ball in autodesk inventor
Unread 14-01-2012, 18:30
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
blackrocks0 is an unknown quantity at this point
Re: HELP!!
http://www.youtube.com/watch?v=rv0HAUC8p6c
Unread 14-01-2012, 20:59
DonRotolo's Avatar
Back to humble
FRC #0832
Re: HELP!!
A better thread title, like "How to draw ball in Inventor" might get you more responses. Most people on Chief Delphi see a thread title of "HELP!" and ignore it, since whoever came up with that probably can't even formulate a good question.
Sketch a 2D circle, put an axis through the centerpoint, and rotate it around that axis. Color it orange if that makes you feel better.
Unread 14-01-2012, 21:02
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: HELP!!
I agree that a better title was needed. I shoot right to the help threads but if every one uses that as a title it gets confusing fast. Also I have to scroll over the title to see what you are actually asking.
Every day is a new adventure!!!
Unread 14-01-2012, 21:09
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: HELP!!
And to add to Don's reply, I usually find it helpful to put a tiny flat spot on the sphere to give you a "pick point" seeing as most CAD programs won't let you grab or constrain a tangent point on a curved surface.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 14-01-2012, 23:47
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Help how to draw a basketball in Inventor.
I helped you by updating the title to reflect your question and moved it to the CAD forum.
Since you are new around here, I would suggest you take a look at the New User threads and get a feel for the community around here. Oh and by the way good luck this year and congratulations on making it through week one!
-Michael Dessingue
Unread 21-01-2012, 11:12
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
You can download one from here:
http://www.chiefdelphi.com/forums/sh...d.php?t=100768
Unread 21-01-2012, 20:33
Mara's Avatar
Mara Mara is offline
Team 696 Safety Czar
FRC #0696 (Circuit Breakers)
Mara has a little shameless behaviour in the past
I would just create an sphere with an 8" diameter. No need to get fancy
Unread 21-01-2012, 23:06
AKA: Scott
Who's getting fancy here?
Unread 21-01-2012, 23:25
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
If you want to create the black lines that outline the ball for realism there is only one way that I know of to do it. If you create a 2d sketch in a plane outside the ball, you can use any lines from the 2d sketch in a 3d sketch. In the 2d you need to create a u shape that approximates the black lines on the ball. If you then create a 3d sketch, you can project the 2d lines to the surface of the ball and it will wrap around the surface. You can then use a sweep to cut a profile along that 3d sketch.
Once you get the top one in, all it takes us a mirror to the bottom half and you get the fancy curved lines on a basketball.
We just did this in my Design Technology class, it sounds confusing but once you do it it seems really simple. PM me if you get lost and I'd be happy to walk you through it.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 21-01-2012, 23:30
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
I think you can also do it with the emboss function. You draw the basketball pattern on a tangent plane and then emboss it in black, and then mirror it.
Disclaimer: I haven't tried this yet; the only thing like this I've done is raised lettering on a curved bumper shape...
You can't fix something that isn't broken... but you can always break things that aren't fixed!
