Go to Post Never mind the imperial British Empire, the sun never sets on our FIRST season! - artdutra04 [more]
Unread 14-01-2012, 11:25
longhorns1771's Avatar
longhorns1771 longhorns1771 is offline
FRC #1771
longhorns1771 is an unknown quantity at this point
Question What material would be best to build a bridge lowering arm?
My team is in the process of designing an arm that would lower the bridge and be able to do other task such as picking up balls. We where debating wheter we would use Alluminum 8020, regular Alluminum, or cast Iron. In terms of wieght we where wondering which would the most efficient
Longhorns!!
Unread 14-01-2012, 11:28
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: What material would be best to build a bridge lowering arm?
I'd consider plywood, polycarbonate sheet (Lexan), aluminum sheet, tubular aluminum, etc. 80/20 and iron would not even be on my list.
Unread 14-01-2012, 21:04
DonRotolo's Avatar
Back to humble
FRC #0832
Certainly a solid. Gases, liquids and plasmas would cause problems.
Cast iron? Seriously? Aside from it being far too heavy, it is not very tough: It breaks easily.
Most teams will be using aluminum. Some will use wood, or perhaps Lexan. None will use Plexiglas (Acrylic) because it is dangerous.
Unread 14-01-2012, 21:17
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
I'd say an aluminum tube. Our bridge lowering design is simply an aluminum tube connected at each end to two arms that lower and raise the tube.
