Go to Post I think rovers on Mars are way cool but you won't get a crowd of enthusiastic participants cheering as they trudge 150 meters a day. - Andrew Schuetze [more]
Unread 14-01-2012, 20:43
Nikkocharger's Avatar
Nikkocharger Nikkocharger is offline
The R/C'er
AKA: Dontae
FRC #3398 (Crushing Crusaders)
Nikkocharger will become famous soon enoughNikkocharger will become famous soon enough
Question Team worried about robot tipping while crossing rail.
Hello everyone
My team is finished building the prototype chassis but we are worried about the robot tipping while crossing the rail. Since our middle tire is about 3/4 of an inch lower than the front and rear wheel it raises the whole chassis up pretty high. One idea was to make the middle wheels smaller and put omni wheels on either the front or back wheels to aid with turning. How ever we can't put omni's on the front because the may break from being rammed into the railing. We also can't put them in the rear because the robot would lose traction driving onto the ramp.
Also with all of that weight coming down at the same I wondered would this cause excessive weight and stress on the rims causing them to break.
ID:	11370  Click image for larger version
ID:	11371  Click image for larger version
ID:	11372  Click image for larger version
ID:	11373  Click image for larger version
Suddenly, a wild prototype appears!
Unread 14-01-2012, 20:56
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Re: Team worried about robot tipping while crossing rail.
Your middle wheels should be about an 1/8" lower than the outer wheels not 3/4".
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 14-01-2012, 21:10
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Why are your middle wheels lower?
Every day is a new adventure!!!
Unread 14-01-2012, 21:13
The R/C'er
AKA: Dontae
yea I must admit that I was not really paying attention while measuring the wheels in order to post this but I do know we decided to use custom spacers to raise the chassis up a several inches off the ground to clear the rail which is what threw the measurements off some.
Unread 14-01-2012, 21:14
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
6 wheel drive.
you're doing it wrong.
but on a more serious note:
It's very weird how you did your 6 wheel drive; it looks like you leveled the wheels all out evenly?
Middle wheel should be ever so slightly lower so it can grip the floor and provide the actual movement by a motor, back and front wheels should be dead. Wither front or back will touch the floor depending on movement, so no more than 4 wheels will be on the floor at all times (middle and either front or back).
Unread 14-01-2012, 21:15
Standard 6WD trick to keep maneuverability. It shortens the wheelbase, making turning easier.
But 3/4" of an inch is WAY too much for a standard 6WD drop. Those are more often in the 3/16" range. With 3/4" inch, there's a little bit of a tipping worry even when you aren't crossing the rail--all it takes is a hard bumper hit when you're rocking while in acceleration, and your robot is no longer on its wheels.
Unread 14-01-2012, 21:16
the man's Avatar
AKA: Jacob Overla
FRC #4004
Wait why only have 4 touching at once? This seems to be counterproductive. Why not just use a 4 wheel drive at that point?
Unread 14-01-2012, 21:18
Because if you're using a 4WD, your robot bounces all over the place when trying to turn.
The 6WD gives six wheels either contacting or skimming the ground with a shorter wheelbase, which allows for much better turning.
Unread 14-01-2012, 21:24
the man's Avatar
AKA: Jacob Overla
FRC #4004
Humm, I see. I did not know that. That is very interesting. We have never attempted a 4 or 6 wheel normal drive, except for lunacy and that doesn't count. We used mechanums fro 2010. I will definitely keep this in mind for the future.
Unread 14-01-2012, 21:25
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
4 wheels will only be touching at one time. HOWEVER, that does not mean that the 2 other wheels wont be used. Throughout the match all 6 wheels would have been used. Lets say you are acceleration forward, so that means that your middle and back wheels will be touching. The you stop, now your robot wants to keep going, so your front and middle wheels are now touching instead of your back. The middle wheels also act as the pivot point. With 4 wheel drive it is harder to turn if not done properly. If you have all six wheels on the ground at once than it is extremely hard to turn.
Hope that helps explain it
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 15-01-2012, 02:50
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
In addition to what others have said, ideally you would have all 6 wheels powered. In addition for better results in pushing matches, I don't see making it over the barrier to easily without them all powered.
Unread 15-01-2012, 10:28
StealthMentor StealthMentor is offline
FRC #1802
StealthMentor is an unknown quantity at this point
The think tank has some good articles, and videos. This one explains the turning problems with having your driven wheels far apart, center of gravity and other useful information. I would suggest giving it a watch it is worth it.
http://thinktank.wpi.edu/article/8
Unread 15-01-2012, 17:29
teh_lol's Avatar
teh_lol teh_lol is offline
FRC #0486 (Panther Robotics)
Team Role: Driver
teh_lol is an unknown quantity at this point
I don't know if it would help but it seems that you could possibly lower the base with electronics on it, lowering the center of gravity. That would probably make you a little harder to tip.
Unread 15-01-2012, 22:35
Josh N. Josh N. is offline
FRC #0691
Josh N. is an unknown quantity at this point
In the pictures above, it looks as the guy is leaning the Kit-Bot backwards to make it look like the robot was going over the barrier. Is this true, or is the robot actually going over it?
Unread 16-01-2012, 01:28
The R/C'er
AKA: Dontae
All of the wheels will soon be powered the pictures were just taken before we finished the drive-train.
Its a little bit of both he was holding it like that in-order to simulated it going over the railing since the drive-train was not finished.
