Go to Post teams that REALLY deserve to win will find ways to overcome a marginal officiating decision. Also, teams that REALLY deserved to win will try not to put themselves in that position. - Chris Hibner [more]
Unread 14-01-2012, 13:34
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
Exclamation Can not connect to Real-Time target
I'm trying to deploy code on our robot, I just re-imaged it with with the new 2012 LabVIEW. I am trying to push the run button on the robot main so i can get feedback to the gyro. I keep getting an error that says that "Can not connect to Real-Time target" I'm connected to it and can talk to it, what is going on?
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 14-01-2012, 19:49
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Re: Can not connect to Real-Time target
unlike last year, the module that connects to the digital sidecar has to be in slot 2, not slot 4. We had the same problem until we changed it.
Unread 14-01-2012, 22:14
Doc543's Avatar
AKA: Eric
never mind the C-RIO broke anyway
Unread 15-01-2012, 08:31
Greg McKaskle Greg McKaskle is online now
Any details about what broke?
Greg McKaskle
Unread 15-01-2012, 17:10
Did you set the IP address correctly in the project? Is your programming computer using a compatible address?
Unread 16-01-2012, 13:49
Doc543's Avatar
AKA: Eric
yes, yes, and yes I cant even ping the thing anymore, is the a way to reset the ip on it , there might be a chance we can save it.
Unread 16-01-2012, 15:49
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Make sure Windows Firewall is turned off.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 17-01-2012, 00:38
Doc543's Avatar
AKA: Eric
It was working fine, i could talk to it, image it and ping it, all of a sudden, it just stopped talking to me, I am suspecting a bad image, I was changing back and forth from Java to LabVIEW. Could I send it in and get it formatted at NI?
Unread 17-01-2012, 07:24
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
You can format the cRIO yourself using the FRC cRIO Imaging Tool. It should be on your desktop after you install Labview
Unread 17-01-2012, 09:20
ww2freak8 ww2freak8 is offline
FRC #4345
ww2freak8 is an unknown quantity at this point
If I'm not mistaken you can reimage the c-rio using the imaging tool from labview. Our team ram into a problem were we had to turn off the wireless card and firewall to get it to image correctly.
Unread 17-01-2012, 18:56
Doc543's Avatar
AKA: Eric
Well i cant even ping it, ive turned off all other network connections and it sill wont respond to pings and the imaging tool wont find it
Unread 18-01-2012, 13:29
If you put it in safe mode, can the imaging tool see it?
