Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Unread 13-01-2012, 16:51
Pirate programe's Avatar
Pirate programe Pirate programe is offline
FRC #0354
Pirate programe is an unknown quantity at this point
Camera Communication Error
I ran the Setup Axis Camera tool on our 2011 Axis 206 camera, set the accounts and such, then attempted to run the Camera Performance Example project on the robot, but got this error:
Watchdog Expiration: System 3, User 2
ERROR<code> -44003 occured at WPI_CameraIssue HTTP Request with Authentication.vi>>WPI_CameraIssueGet Enum Sensor Property.vi>>WPI_CameraGet Exposure.vi>>WPI_Camera Registry.vi>>WPI_CameraOpen>>Camera Performance Example.vi
<time>16:26:47 01/13/2012
FRC: Operation failed due to a communication failure with the camera.
What could be causing this?
Unread 14-01-2012, 00:56
Re: Camera Communication Error
That error could be caused by many things. What is the camera connected to? What color is the ring around the lens? Is it mounted in a way that will keep the reset button from being accidentally pressed? What IP address is the camera set to, and does that match the address being looked for in the example?
Unread 14-01-2012, 23:21
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
By set accounts did you mean User: FRC Pass: FRC and Ip: 10.xx.xx.11
if so you are correct
Unread 15-01-2012, 11:45
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Issues have been confirmed with the setup utility by the NI rep here. Manual setup is recommended.
Unread 17-01-2012, 15:55
FRC #0354
The 2nd crossover port on the cRIO.
Solid green.
There shouldn't be anything touching the button, if there is the camera isn't showing any signs of resetting.
Since it's plugged into the cRIO, it's set to 192.168.0.90, and I've set that in the code as well.
Also, we can get an image from the camera in the Front Panel of the Camera Performance Example.vi, and now we need to get it to display on the FRC Dashboard.
Unread 17-01-2012, 17:56
cgmv123's Avatar
AKA: Max Vrany
I believe that the dashboard expects the camera to be plugged into the D-Link at 10.te.am.11. Running through the cRIO may require configuration.
Unread 17-01-2012, 18:10
FRC #0354
What kind of configuration would this require?
Unread 17-01-2012, 18:56
To run it through the cRIO instead of the normal DLink connection, you'd need to add a vi to forward the image on to the Dashboard.
And of course modify the Dashboard to accept images from the cRIO instead of directly from the camera.
The Dashboard camera display will run more slowly coming through the cRIO than through normal network channels.
Unread 17-01-2012, 21:25
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
I believe we are having a similar if not the exact same problem. The main goal for our controls team today was to set up our camera. We worked through the “2012 FRC Getting Started with the 2012 FRC Controls System: How to Configure Your Camera” instructions exactly. And it all seemed to go splendidly. We had a green power light on the camera so we know the hardware was set up correctly. We then loaded the basic framework code on to the robot. However, we saw no image in the Dashboard screen, just a blank white space. We then opened Begin.vi and put on execution highlighting. An error popped up under ‘Open FPS’ (Frames Per Second). We had not changed the framework so it was set to the default of 12. We even swapped out the crossover cable to eliminate the possibility of that problem. We would like to see the camera image in the Dashboard but are currently unable to. Could anyone point out where we erred or what else we need to do to accomplish this task?
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 18-01-2012, 05:33
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
We were plugged into the 8 port crio and not the dlink. we will rework, having more closely read the instructions. (this is in the first line of the instructions, we should have seen this)
http://www.team1912.com
2013, 2012, 2011, 2010 Regional Chairman's Award, Bayou Regional
2013 Woodie Flower's Award, Bayou Regional
2012 Dean's List Winner (Rachel Holladay)
2015, 2014, 2013, 2012, 2011, 2010 Beta Test Labview/Hardware
2012, 2011 Best Website, Bayou Regional
2011, 2009, 2006 Gracious Professionalism
2007 Bayou Regional Winner
