Go to Post Dean Kamen is my Shaquille O'niel (or any other generic sports star). - Daniel Brim [more]
Unread 14-01-2012, 23:27
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Getting speed from an encoder
I want to be able to get the speed of the robot from a quad-encoder what would i have to do to convert the ticks into a speed unit?
Unread 14-01-2012, 23:32
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Getting speed from an encoder
private double[] getRPM()
        double rpm[] = new double[2];                                               //Declares an array of integers which the function will return.
        currentTime = time.get();                                                   //Sets currentTime to the time calculatged from FPGA
        rpm[0] = leftEncoder.getRaw() * 16666666.666666 / currentTime;              //dAngle*(60000000us/360deg)/dTime = RPM
        rpm[1] = rightEncoder.getRaw() * 16666666.666666 / currentTime;             //dAngle*(60000000us/360deg)/dTime = RPM
        leftEncoder.reset();                                                        //Resets the left wheel encoder.
        rightEncoder.reset();                                                       //Resets the right wheel encoder.
        time.reset();                                                               //This resets the timer.
        return rpm;
Unread 14-01-2012, 23:35
FRC #0228 (Gus)
Great thanks, will try this out soon
Edit:
where do you get the currentTime function?
Unread 14-01-2012, 23:39
techkid86's Avatar
techkid86 techkid86 is offline
Magic Programer
FRC #3044 (0xBE4)
techkid86 is an unknown quantity at this point
i am not sure if this will give the same result, but the WPI libs already have an encoder class, and it can give rate in distance. theoretically this is the same, but what ever. im not sure if you are writing your own, but, if you want just he encoder funtions, they are as follows.
Encoder.setDistancePerPulse(x);
Encoder.getRate();
not sure what you wanted but i hope i could help ^_^ good luck ^_^
"you can build a perfect machine out of imperfect parts" -Urza
Unread 14-01-2012, 23:42
FRC #0228 (Gus)
Encoder.getRate();
Thankyou ill try both
