Re: FlyWheel Prototype Help
Try switching out the wheels to ones with more friction.
Are there skid marks on the ball? You arn't getting any spped increase because the increased speed is just reducing the amount the wheel can grip the ball. These factors just cancel so the ball kind of hits a point where it wont go any faster and go a greater distance. I mean, just think about it. If the wheel is going faster, then it would have to grab more the pull the ball with it (Since the ball has inertia and resists the acceleration) All the wheels force is being imparted via friction, and you have reached the max amount of force the wheel can impart with the amount of friction you currently have. Compression would help. Try those wheels that have that orange rubber blunt-spikey stuff on it. Lets see what those do to the ball before you even add more compression ![]() |
try cutting a little bit of the end of the board part its hitting the board last u dont want that u want it touching the wheel last.
Having the ball release off a backplate isn't a bad thing if you do it right--you just change the speed and angle and spin by having it go off the plate last as opposed to releasing off the wheel last. Oh, and releasing off the wheel last may have its own problems, like reducing spin. It's all in the setup. |
