Go to Post IF WildstangIsAwesome = True and SkaIsAwesome THEN Act = AWESOME End IF - Rohith Surampudi [more]
Unread 15-01-2012, 01:29
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Attaching sprocket to a pneumatic wheel?
Hey all,
We're thinking of getting this wheel for our robot, and were wondering how we would go about attaching bearings/sprocket or whatever else we need to get this going on our robot.
Thanks!
Unread 15-01-2012, 01:39
I LOVE ROBOTS!'s Avatar
I LOVE ROBOTS! I LOVE ROBOTS! is offline
KING TRIDENT! MASTER OF TMACILAC
AKA: dakota ewigman
FRC #1730 (Team Driven)
Team Role: CAD
I LOVE ROBOTS! is a name known to allI LOVE ROBOTS! is a name known to allI LOVE ROBOTS! is a name known to allI LOVE ROBOTS! is a name known to allI LOVE ROBOTS! is a name known to allI LOVE ROBOTS! is a name known to all
Re: Attaching sprocket to a pneumatic wheel?
perhaps machine a hub that utilizes that 4 bolt bolt pattern, or possibly put that pattern on your sprockets and use some standoffs. and it looks like it already has bearings. the only other ideas that come to my head this late at night would be a nightmare so I'll just leave them in my head
Unread 15-01-2012, 01:58
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Also know that wheel is quite heavy....
But your best bet is probably using stand offs and getting longer bolts.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 15-01-2012, 07:13
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
We recommend milling your own hub for these wheels. Nothing from Andymark can be made to fit them.
Unread 15-01-2012, 08:25
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
We are using the same wheel. Saying that nothing from andymark will fit is incorrect. The kop 26 tooth sprocket has an id that fits over the hub, however it is a little oversize. We used a plasma cutter to cut some flanges that we are welding to the end of the extended hub. We will then mount the stock andymark sprocket to that new flange. Those wheels are more than robust enough to hold up too, our lead mentor used them for a go kart for his kids and they ran it with a gas engine and two kids rising it for a whole summer before it broke. As with any plan, always make spares...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 15-01-2012, 11:49
mrnoble's Avatar
teacher/coach
I misspoke; what I should have said was, we didn't find any hubs from andymark that we could modify to attach any better than hubs that we make ourselves. The wheels are heavy, but are super cheap right now, at $3.49 each. We are going to try them out this week and see if they are "worth the weight" for getting over the bump. best of luck!
Unread 15-01-2012, 12:15
I would honestly recommend this instead http://www.andymark.com/product-p/am-0970.htm
Unread 15-01-2012, 13:16
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Seconded.
Team #88, TJ2
Unread 15-01-2012, 13:36
The only issue with an 8" wheel compared to a 10" wheel is the extra force needed to climb the obstacle. An 8" wheel means you are hitting the barrier with the wheel climbing vertically due to the center of the wheel being at or slightly below the barrier's total height. The modifications necessary to make a 10" $4 wheel work took us the better part of one afternoon to complete and with a little help from local welders we can have a very simple and cheap means of handling anything that the field can throw at us.
Also, our team has a very limited budget, as I'm sure others do as well. Spending $15 per wheel is much easier to swallow with a little work than spending $60+ for one that is just a bolt on. When you look at six wheels, we save $270... that's more than we spent on all of the parts we put on our rookie year robot...
Andrew Basse
Unread 15-01-2012, 13:47
Do you have pictures of your modifications?
Unread 15-01-2012, 14:25
They are being welded over the weekend and we will get some up when we return to school on Tuesday. I am working on getting my students up to speed with a CAD file as well, but we only have 14 kids and only two of them have interest in CAD.
Basically picture a cheap ten inch tire like this one
the other side of the hub has a extension that spaces out the pressed in bearings. We cut a 3/16" thick ring using our CNC plasma cutter that is being welded flush with the end of that hub extension. We will drill the proper holes and bolt the andymark sprockets from the kop to that ring.
A lot of posts have come up recently about these wheels and using spacers to make use of the 4 bolts that hold the hubs together. We looked at that option but didn't like the size required and cost associated with using a sprocket that would fit around those four holes. Here is a really bad representation that I just threw together in Inventor
Andrew Basse
Unread 15-01-2012, 14:57
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Another factor to consider is the weight impact.
The Harbor Freight wheel is 3.9 lbs. The AM wheel is 1.1.
With a 4WD this is 16 pounds compared to 5.
With a 6 WD is is 24 compared to 7.
There are many factors to consider, weight should be included.
If your are able to make the HF wheel work and manage the weight, that is cool. There is always a tradeoff of weight, cost, availability and capability.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 15-01-2012, 15:10
Mk.32's Avatar
AKA: Mark
Also look at the skywaywheels for cheap and relative light tires.
They have a 10x3 inch pneumatic wheel.
http://www.skywaywheels.com/usfirst.htm just give them a call and they will send over any info you need.
Unread 15-01-2012, 15:20
mrnoble's Avatar
teacher/coach
you're all going to react in horror, but we made our hubs out of quartersawn white oak, turned on the lathe and broached for the hex axle using chisels. Most of our bots for the last several years have been made of wood to some degree or other, as woodworking is the program our robotics team grew out of. We've had great results (by our standards), because wood is tough, durable, and easy to manufacture. So far they look like they will hold up well, but as has been said already, the weight may make us change our minds later. We'll see!
Unread 15-01-2012, 15:27
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
BAM Team 237 also used Skyway wheels.
BAM = Before AndyMark
