Go to Post Building a robot is one thing - but the fun I have had with my mentors, parents, and other students on team outings is something I cherish. - SuperJake [more]
Unread 15-12-2001, 00:25
Andrew Wyatt Andrew Wyatt is offline
#0524 (Alpha Omega Robotics)
Andrew Wyatt is an unknown quantity at this point
Send a message via AIM to Andrew Wyatt
connectors
Our team used the db25 and 15 connectors with the crimp on pins to good effect, they're easier to work with, you can remove pins and move them over if you screw up and you don't have to worry about accidently connecting two pins together with solder.
There are only two tools you really need: duct tape and Wd40. if it moves and it shouldn't, use the tape. if it should move and doesn't, use the wd40.
So what happened at the FIRST forum Todd Derbyshire General Forum 57 05-08-2002 22:18
