Go to Post Past success does not guarantee future results.... - Koko Ed [more]
Unread 14-01-2012, 20:52
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Dashboard/SmartDashboard
Could I get any help with these. I have made several attempts but it does not seem to work no matter what I try, Any working examples in particular would be very helpful.
Unread 14-01-2012, 22:14
Hobson's Avatar
Hobson Hobson is offline
Head Coach - FLL LA State Head Ref
Hobson is an unknown quantity at this point
Re: Dashboard/SmartDashboard
What do you mean Gus? Add some description of what's going on?
Unread 15-01-2012, 07:38
gixxy's Avatar
I setup my code up to send the current value of the Jaguars to the Dashboard, however it never seemed to update anything. However I never got a chance retest it after fixing the cable, somehow I don't think that was the problem.
Unread 25-01-2012, 22:14
Ipiano's Avatar
Ipiano Ipiano is offline
AKA: Andrew Stelter
FRC #3018 (Nordic Storm)
Ipiano is an unknown quantity at this point
I've been working the SmartDashboard myself and have been getting pretty good results, so I will try to help if I can.
What exactly are you trying to do and what are the results you are getting?
________
Genius is one percent inspiration and ninety-nine percent perspiration.
--Thomas A. Edison
Unread 25-01-2012, 22:42
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Try following the steps of the guideo n my team's site. THis is what worked for us. It's not much yet (We're still working on the guide), but its enough to get the dashboard configured properly on your computer. This is the area we found the documentation lacking.
http://team2168.org/index.php/resour...smartdashboard
http://team2168.org
Unread 26-01-2012, 13:54
Ipiano's Avatar
AKA: Andrew Stelter
You also might want to take a look a this,http://firstforge.wpi.edu/sf/go/doc1297;jsessionid=54BA7DA57ABC06B2BBC6CDC0EF512C7 A?nav=1. It's very handy for the new command-based coding, and at the end(p. 70ish) theres a section about the smartDashboard, that's where I got most of my information. A lot of it is blank, I'm not sure why, maybe they're just implying that you can do the stuff in the headings, or maybe there will be another release.
________
--Thomas A. Edison
Unread 27-01-2012, 16:10
AKA: Brad
#0190 ( Gompei and the Herd)
Also, check out the video on the SmartDashboard here:
http://youtube.com/user/bradamiller
Brad
Brad Miller
Robotics Resource Center
