Go to Post I'd also like to apologize to any of the teams whose robots we may have broken. - Ginger Power [more]
Unread 15-01-2012, 09:51
Re: Banebots Motor Question
Originally Posted by jason701802 View Post
I would use the 775 motor before anything for any high-power scoring need (I'm assuming all 4 CIMs would be used up in the drive-train) as it is the third most powerful motor in the KOP (following the CIM and only 18W less than the -0673 FP) and its size allows it to handle high load and stall conditions much better and longer than a 550 or smaller motor.
Here's some data, FWIW:
550-12 stalled at 12 volts: 70.5 ozin torque and 1020 watts heating.
775-18 stalled at 7.5 volts: 70.5 ozin torque and 406 watts heating.
Unread 15-01-2012, 11:16
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The Banebots P60 gearboxes should be perfectly fine for powering a shooter wheel. As Adam said, you start running into problems if you use them in large reductions driving high inertias with shock loads. The failure point is actually where the output shaft meets the final stage carrier plate. It's a "Double-D" shaft/hole connection that's highly prone to deforming and camming out under shock loads. A low reduction gearbox into a shooter wheel just isn't going to have this problem.
As for lead times, last year was obviously horrendous with 20 day lead times or more. BB is currently stating up to 6 day lead times on orders. I think the lead time gets bad because they have such a modular system and they build each gearbox to order.
PROTIP: If you need a P60 gearbox RIGHT NOW, order all the individual parts for it and assemble it yourself.
Last year at the height of the 25-30 day lead times, we ordered wheels and spare P60 parts from BB and they shipped in 2-3 days. So I'm pretty certain you could just order all the various parts you need and they'd ship out much much faster.
