Go to Post Scoring ringers is going to be like dating. While a select few will master it with relative ease, the vast majority will need quite a bit of time to refine their skills to an acceptable level. - artdutra04 [more]
Unread 15-01-2012, 10:29
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
Re: Cim-u-lator Gearbox
Thank you so much CD-community!!! You guys rock!
I was just wondering...from the CAD and pictures it seems as if the output shaft isnt keyed! Can someone please confirm or deny this?
Also the 2.7:1 ratio might be good for this years shooter, more rpm under equal compression should equal a higher distance.
Again Thanks!!!
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 15-01-2012, 11:09
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Again Thanks!!!
The output shaft is definitely keyed. As it turns out, all my blurry pathetic pictures don't show it very well. You can barely see it in one picture in the gallery though -- attached.
Cheers,
Joe J.
Team #88, TJ2
Unread 15-01-2012, 15:44
Feroz1325's Avatar
Dr.Joe your pictures are nowhere near pathetic....seeing as before your pictures my team and I had no idea what the CIM-U-LATOR looked like (our teacher sponsor even thought it was a scam ). Thank you very much, how has your experience with the gearboxes been? Any hints, pointers or things to look out for?
Feroz Balsara
Team1325.com
Unread 16-01-2012, 23:53
AKA: Dr. Joe
FRC #0088 (TJ2)
I haven't put them to use as I found a way to do what I want without them. I've never put power to them.
And yet, they have a surprisingly high quality feel to them. I think that for what they do, they are could be pretty good.
Joe J.
Team #88, TJ2
Unread 17-01-2012, 11:05
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Cim-u-lator (550 comments),
I used the Banebots $30 coupon to offset the of purchase 2 - 550 motors and the 550 cim-u-lator gearbox. I hand assembled the unit and thought it went together well.
If you are planning on using 2 motors in your Cim-u-lator like I had planned you should be aware that you are missing some components. You will need a 2nd pinion gear that Banebots sells (PN missng here) as well as 2 small machine screws and lock washers (PN??) to mount the unit. The unit comes equipped to mount just one motor.
If I had to do it again, I might have used my Bane Bucks to get the 775 Cimulator and a 775 18 volt rated motor and try to use this configuration in a belt driven application for the shooter which would keep all 4 CIM motors available for traction/propulsion
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 17-01-2012, 12:24
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Joe J.
Joe,
Do you have an opinion on the quality of the Cim-sim?
It has bad reviews on AM and I am mostly just curious.
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 17-01-2012, 14:53
UkuleleGuy's Avatar
UkuleleGuy UkuleleGuy is offline
AKA: Wesley Liao
FRC #3660 (Lightsabers)
UkuleleGuy is an unknown quantity at this point
We received a 500-type CIM-U-LATOR today in the mail, and I took a few pictures.
So far I really like it, according to my calculations based on the RS550 spec sheet, it should have an rpm of 7100 and a stall torque of 370 oz-in.
Compare to the CIM motor's 5310 rpm and 340 oz-in of torque.
Only downfall I see is that it requires two motor controllers.
Anyway, my two cents.
Attached: Kit contents, detail of housing
ID:	11422  Click image for larger version
Unread 03-02-2012, 16:36
mehrkam's Avatar
mehrkam mehrkam is offline
Paul Mehrkam
FRC #0836 (Robobees 836)
mehrkam is on a distinguished road
We have had some trouble with a dual CIM-u-lator using 2 550s. For some reason the motors overheat extremely fast. We mounted this on our test shooter and instantly had smoke coming out of them. The only way we could run them was to put the big cooling fan blowing down on top. Even with that, the motors toasted after some test runs and case shorted.
Have you had any success with yours?
We have decided to stick with the single CIM-u-lator using the 775-18V with cooling. The final design will have cooling fins installed on the motor.
Unread 03-02-2012, 16:49
probably for reason#3:
http://www.chiefdelphi.com/forums/sh...3&postcount=15
Unread 03-02-2012, 17:12
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
We have had some trouble with a dual CIM-u-lator using 2 550s. For some reason the motors overheat extremely fast. We mounted this on our test shooter and instantly had smoke coming out of them. The only way we could run them was to put the big cooling fan blowing down on top....
Did you make a provision for allowing cooling air to enter the front of the motor?
If there is no air flow through the motor, it's going to heat up in a hurry!
As an example, the FP motors come with this orange plastic ring around the central hub of the motor on the output shaft end. If you leave that ring in place when mounting them on a CIM-Sim or CIM-u-lator, then air can flow in. If you remove it, the motors stop breathing.
One simple option you can try is drilling four holes in the motor mounding plate in alignment with the vents in the motor. The larger, the better..... to a point of course.
Unread 03-02-2012, 18:13
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
I don't have a CIMulator in front of me, but judging from the attached photos a few posts up, this gearbox doesn't appear to have any holes or pockets to allow airflow into the motor vents. It seems odd that this feature would be omitted/forgotton on the CIMulator, as the P60 gearbox I have on my desk has two pockets on either side of the center motor boss to allow air to enter the motor vents from the side of the gearbox.
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-02-2012, 18:29
See attached screenshot from Banebots web page for the CIMULATOR.
Does this have any bearing on the cooling issue? I've not seen the CIMULATOR so it's unclear why the 775-18 is the only recommended motor.
