Go to Post you should see my scout sheet its the bomb diggity - Mirza95vx [more]
Unread 09-01-2012, 22:25
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Re: [Rookie] How to set up electrical the best way?
Zip ties do a good job of keeping masses of wiring neat, and can be easily cut away if needed.
Also labeling speed controllers and fuses helps. Especially with CAN when the jaguars have addresses.
Example of one of the boards i did that initially wasn't great, but zip ties made it much neater and easier to follow wires:
http://www.vandenrobotics.com/plogge...n/sn850239.JPG
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 09-01-2012, 22:46
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
I'd recommend adding corresponding letter or number labels on the end of each wire, then a wiring list describing the gauge of each wire, it's source and destination, as well as its function. A wiring list takes a bit of time to set up, but is hugely beneficial for quick fixes. It eliminates the need to trace a wire through webs and nests that will almost certainly build up on your robot.
Unread 10-01-2012, 00:33
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Keep in mind that this board is missing a circuit breaker, which you must have (you seem to be referring to it as the "killswitch").
Other things that you may want to take a look at are spiral wrap and the plastic routing chain that comes in the igus bag. They're both handy ways of protecting long wire runs, and in the case of the latter, ensuring a constant direction of motion for said wire run as you actuate an appendage.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 10-01-2012, 01:18
Thanks for mentioning that, i forgot ours was elsewhere on the robot that year.
You may someday decide to make your electronics removable like that panel, in which case certain crimps make it easier to remove and replace quickly like these anderson connectors. (also pictured in the left corner of the electronics panel i posted)
http://www.powerwerx.com/anderson-po...owerpole-sets/
Unread 11-01-2012, 00:07
Steven,
A very pretty wiring job! Congrats.
Unread 11-01-2012, 03:07
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Here is our software development bot. It is in a smaller footprint than the competition robot so it is less intimating when testing software. We are trying Jaguars for the first time and we made a backbone CAN bus (not daisy chain so it won't have the problem of one Jag dies, all down stream jags will fail) using RJ-12 connectors. The bus is pretty much two twisted-pair wires punchdown to 4 RJ-12 connectors. Also notice the Anderson connectors for motor power and RJ-11 connectors for the encoders. So unplugging all motor power and encoder cables will allow us to separate the electronics from the frame cleanly.
ID:	11316  Click image for larger version
ID:	11317  Click image for larger version
ID:	11318  Click image for larger version
Last edited by mikets : 11-01-2012 at 06:17. Reason: Scale down picture size to allow upload.
Unread 15-01-2012, 03:31
imjessica's Avatar
imjessica imjessica is offline
AKA: Jessica
FRC #4159 (CardinalBotics)
imjessica is a jewel in the roughimjessica is a jewel in the roughimjessica is a jewel in the rough
what is the white box on the right onthis picture? http://www.chiefdelphi.com/forums/at...6&d=1326270641
sorry im just gonna assume that was a silly question. haha thanks
Unread 15-01-2012, 11:49
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Looks like a CAN device. If you're driving the Jaguars with PWM, you don't need to worry about it.
Unread 15-01-2012, 17:29
It appears to be a CAN hub of some sort. Instead of wiring from Jaguar to Jaguar as is expected, I think that robot has the CAN connections going from each Jaguar to a central, likely custom-built, box.
Unread 15-01-2012, 20:27
mikets's Avatar
Software Engineer
Yes, that's a CAN bus backbone. All Jaguars are running as a T-tap to the CAN bus backbone. So there is no issue of daisy chaining where one segment has problem and all down stream Jags are disabled. The box is just an RJ connector plate with 4 RJ-11 connectors. Two pairs of twisted wires form the backbone of the CAN bus. One power pair, one CAN-H CAN-L pair. The wire pairs are routed around each connectors with a punch-down tool. Very reliable. At the end of the CAN-H, CAN-L pair is a terminating 100-ohm resistor. The other end of the pairs is terminated to a RJ-11 male connector and plugged into the 2CAN.
Unread 23-01-2012, 13:15
djdaugherty djdaugherty is offline
Mrs. D.
FRC #2053 (TigerTronics)
djdaugherty is on a distinguished road
I have a question about the Anderson Connectors....Do you use 30 A connectors and 45 A connectors (depending on the breaker) or just stick with 45A connectors for everything? It looks like the size of the housing doesn't change.
Unread 23-01-2012, 13:33
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Do you have pictures of the inside of the box, I'm not quite sure I have a clear picture of what's going on inside. This seems like a great way to eliminate one of the problems with CAN.
Unread 23-01-2012, 13:43
mikets's Avatar
Software Engineer
I am making a 12-port CAN backbone tonight. I will take some pictures to post.
Unread 23-01-2012, 15:45
We use the 45 amp connectors exclusively.
Unread 23-01-2012, 15:59
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
We use the size that is appropriate for the wire. You can have difficulty getting a good crimp if your wire is too small for the connector! You are correct, the housing size is the same, although you can get it in many different colors to help keep your robot organized!
