Go to Post If this thread isn't a sign that CD is going through some serious withdrawals, I don't know what is. - Ty Tremblay [more]
Unread 15-01-2012, 14:41
SoyStuff SoyStuff is offline
FRC #1257
SoyStuff is a jewel in the roughSoyStuff is a jewel in the roughSoyStuff is a jewel in the rough
Window Motors and Rotation
What exactly is a window motor and how would I go about coding for one in C++? Is it just a special jaguar? Also, I have some plans for autonomous mode, but I need to know how to rotate something in increments of five degrees. Is there a way to turn a motor a precise number of degrees.
Any help you can offer is appreciated.
Thanks.
Unread 15-01-2012, 15:01
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: Window Motors and Rotation
Well a window motor is the motor used to raise a window in your car. It is a medium sized motor attached to a gear box that significantly reduces speed but it is a very strong motor. as for coding thats not my area but I couldnt imagine it would be any different from any other motor. I believe you are looking for an encoder to give feed back of how far the motor is rotating, but again that is not my area.
Every day is a new adventure!!!
Unread 15-01-2012, 16:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
A Jaguar is a speed controller, it is an electronic device connects in between the cRio and a motor, to control how much electric power goes to the motor.
A window motor is an electric motor, just as a CIM or a Fisher Price motor is an electric motor. The window motors turn relatively slowly.
to control how many degrees a motor turns, usually requires an encoder, and a feedback loop such as PID.
Unread 15-01-2012, 21:05
beiju's Avatar
beiju beiju is offline
Growing Chief Delphi Addict
AKA: Will Pryor
FRC #3120 (RoboKnights)
beiju is an unknown quantity at this point
squirrel and the man are correct. As far as any programming is concerned, a window motor is identical to any other motor. It sounds like you're using it as it was intended, which is to reposition elements of your car/robot.
To turn a motor to a precise position, you need an external sensor. Often an encoder is the easiest to mount, but window motors are not designed to have encoders and so don't have an easy place to mount them. In the past, my team has used window motors to switch an element between two positions with limit switches that are triggered when the element has reached its intended position. If your element has multiple positions, investigate sensors that are triggered by touch but allow the element to move past them (if something continues moving after triggering a limit switch, it bends and sometimes breaks the switch).
Good luck!
Unread 15-01-2012, 21:11
Just put a flexible extension on the limit switch lever.
Unread 16-01-2012, 09:37
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Note that there are known compatibility issues with the Jaguars and Window motors. You can either remove the locking pins from the Window motors or use Victors or Spikes.
Unread 16-01-2012, 10:22
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Window motors are very small and not very powerful compared many other motors available to you. I really want to say only 20-40 watts, but I can't find the motor spec sheet off-hand.
We have controlled them using spikes instead of jaguars with no ill effect, they turn so slowly we haven't found the need for speed control in any of our applications.
Unread 16-01-2012, 10:33
The KOP window motors stall at right around 20 amps and can be controlled by a Spike if speed control isn't a requirement. However, an ARA window motor might have a different stall current and may require something with greater current capabilities.
Unread 16-01-2012, 11:44
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Note the "locking pin" issue only applies to those motors that have locking pins like those supplied in previous years KOP. If you are using window motors from the ARA program that may not apply.
Unread 16-01-2012, 11:46
the man's Avatar
AKA: Jacob Overla
FRC #4004
These motors work great in applications where speed is not needed. They have a fair amount of torque.
Unread 17-01-2012, 08:12
They also work best in applications where they're not going to stall. They are designed with a thermal cutout that shuts them off for several seconds if they're asked to push against something that doesn't move.
Unread 17-01-2012, 09:02
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
In my experience it will take several minutes for the thermal cutout to reset, so plan on the motor being out of commission for at least the rest of the match.
Unread 17-01-2012, 09:07
Ross3098's Avatar
Ross3098 Ross3098 is offline
Programmer
AKA: Colin Ross
FRC #3098 (The Captains)
Ross3098 will become famous soon enoughRoss3098 will become famous soon enough
Last year our team used a potentiometer attached to our four-bar arm assembly.
(We did use two window motors.)
2012 FRC Championship: 4th pick, Quarterfinalist: Thanks 1507, 51!
2012 Michigan State Championship: 4th Seed, 3rd Alliance Captain, Semifinalist: Thanks 33 and 2137!
2012 Northville District: 3rd Pick, Quarterfinalist. Thanks 302, 4405!
2012 Waterford District: 2nd Pick, Finalist. Thanks 573, 3601!
2011 Waterford District: 8th seed, 1st pick, Semi Finalist. Thanks to 573 and 3770
2011 Ann Arbor District: 2nd seed, Finalist. Thanks to 548 and 247.
2011 Michigan State Championship: Semi Finalist. Thanks to 548 (Again) and 74.
2011 FIRST World Championship: 8th seed, Quarterfinalist. Thanks to 74(Again) and 846.
Unread 17-01-2012, 12:36
Mr V's Avatar
FRC #5588 (Reign)
Again that doesn't apply to all window motors get ones from an older Ford or GM that are almost CIM sized and there is no thermal protection built in.
Unread 17-01-2012, 13:44
Roboticsismylif Roboticsismylif is offline
FRC #3513 (TechnoHawks)
Team Role: CAD
Roboticsismylif is an unknown quantity at this point
Thanks.
You should have gotten 4 window motors, two right and two left. They have moderate speed and lots of torque. As for coding they use a "spike" relay. The coding should be the same for them as any other spike. With the spike you can reverse the flow of energy making the window motor turn the opposite dirrection.
