Go to Post Incidentally, this is a good example of why lawyering the FIRST rules is good practice for the real world. By critically analyzing FIRST's errors, you practice for the day when you need to critically analyze legislators' errors (and deliberate trickery). - Tristan Lall [more]
Unread 14-01-2012, 16:19
CodeMonkey's Avatar
CodeMonkey CodeMonkey is offline
Self Proclaimed Ruler of Universe
AKA: Omar Issa Attar
FRC #0599 (Robodox)
CodeMonkey is an unknown quantity at this point
Kinect Server not working
I have been trying to get the Kinect Server to work with the Kinect but I have had no luck. I have downloaded the SDK and Visual C++ Express and I have .NET framework 4.0. I can connect the Kinect to the computer and the Skeletal Viewer and the Sample Game work. However whenever I try to open the Kinect Server a window flashes that says 'Please insert a Kinect Sensor into PC.' Does anyone know anything about this.
Thanks
Unread 14-01-2012, 16:28
Re: Kinect Server not working
Thanks
What is the Kinect light and message on the Diagnostics tab of the Driver Station saying?
Unread 14-01-2012, 16:42
CodeMonkey's Avatar
FRC #0599 (Robodox)
When I try to use the Kinect server on another laptop (without the driver station), the light on the Kinect is flashing green and the light on the connector is a solid green. When connected to the driver station the light on the Kinect is flashing green and the driver station is also green, so it reads it.
Unread 14-01-2012, 16:45
It sounds like it is working. The Kinect Server appears to be designed to hide itself like that. Probably so your Dashboard and DS can take up the whole screen. Displaying the Kinect video probably ups the processing requirements as well.
Unread 14-01-2012, 16:52
CodeMonkey's Avatar
FRC #0599 (Robodox)
No. I get a message that says 'Please insert Kinect Sensor in PC'. The message flashes and disappears.
Unread 14-01-2012, 17:06
Based on the Kinect Server source code, that's exactly what it is supposed to do. If the Kinect light on the diagnostics tab is green I would expect that means the Kinect is working.
Unread 14-01-2012, 17:30
If you have a green halo around the Kinect on the Operate tab, or a green LED on the diagnostics tab, the next step is to flip the dashboard tab to Kinect and put a person about five feet in front of the Kinect. Sometimes it takes a few seconds to lock on, and I've found that putting your arms up and into your body like Kimg Tut often speeds this up.
Greg Mckaskle
Unread 14-01-2012, 21:44
CodeMonkey's Avatar
FRC #0599 (Robodox)
Yeah. I looked at the source code and realized that the popup was its function and it is working. thanks
Unread 15-01-2012, 15:19
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
For the camera issue everyone, we just Manually Configured it. It works all the time now. Make sure you make an FRC account when you do the manual configuration or it wont work.
-Eagle Engineering 1138
