Go to Post Just goes to show that you don't need to be like everyone else to make it to Einstein. - O'Sancheski [more]
  #31   Spotlight this post!
Unread 14-01-2012, 21:27
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: cRIO updating to v43 Image issue
Originally Posted by compwiztobe View Post
Any ideas?
Read Mark McLeod's post #19. Some things to try. Post what happens if you try them.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
  #32   Spotlight this post!
Unread 14-01-2012, 21:58
Originally Posted by KenBudnik View Post
Not sure what to try next. Frustrating.
That sounds like when comm gets dropped at the point of the changing of the cRIO IP address.
  • Disable ALL unused PC network connections, leaving only the Ethernet port active.
  • Set the Ethernet port to your 10.xx.yy.5
  • Connect the PC Ethernet port to the robot bridge (or any network switch really)
  • Connect the cRIO to the network switch as well
  • Attempt to Image the cRIO
P.S. If you have network connection issues, some general recommendations:
  • Turn off PC firewall
  • Turn off anti-virus
  • Turn off all network ports, except for the one you're using for the cRIO
  • Check IP addresses all along the line
  • Look to see what all the cRIO status lights are doing, particularly Status, Power, & FPGA
  • Look at the Ethernet connection status lights all along the line: PC port, switch ports, cRIO port
  #33   Spotlight this post!
Unread 14-01-2012, 23:09
279 EMPIE's Avatar
279 EMPIE 279 EMPIE is offline
Head Progammer
AKA: Matthew Empie
FRC #0279 (Tech Fusion)
279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice
Send a message via AIM to 279 EMPIE
Red face Re: cRIO updating to v43 Image issue
Where is the imaging tool located?
Was it supposed to download with the USB or is it on wind river?
2011- Programmer, Electrical, and Web
Cleveland Regional
2012- Head Programmer, Web, Driver
Pittsburg Regional, Saint Louis International
2013- Head Programmer
Cinnicinatti Regional, Taraho Regional
  #34   Spotlight this post!
Unread 15-01-2012, 00:53
Aren Siekmeier's Avatar
on walkabout
Yeah sorry, forgot to mention that we tried exactly that. No changes. We are suspecting (based on some tips from a friend) perhaps a Windows firewall issue, and will check that out tomorrow.
  #35   Spotlight this post!
Unread 15-01-2012, 07:23
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
Booting in Safe Mode solved the issue, thank you!
  #36   Spotlight this post!
Unread 15-01-2012, 08:23
In the Utilities Update: http://joule.ni.com/nidu/cds/view/p/id/2262
Check the bottom of the KOP Website to see if you missed other necessary Updates.
  #37   Spotlight this post!
Unread 15-01-2012, 16:05
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Has anyone seen this re-imaging error message?
Unable to complete operation because of unexpected error:
Error -2147220304 occurred at nisyscfg.lvlib:Restart.vi:1
Possible reason(s):
NI System Configuration: (Hex 0x800404B0) Timeout while waiting for reboot. System is offline.
Complete call chain:
ConfigUtility.lvlib:2012_FormatSystem.vi
ConfigUtility.lvlib:ReImageTarget.vi
ConfigUtility.lvlibialog.vi
The imaging tool version is 2011.11.18
The image is FRC_2012_v43.zip
When opening the re-imaging tool for the first time, it correctly identified the cRIO and its' current configuration... so appears to work somewhat and there doesn't seem to be an IP communication issue.
When attempting to re-image normally, the progress box indicates it has made connection, checked the dip switch settings, and was reformating. Then the error.
Tried to reformat in safe mode. Correctly indicated that a reformat was necessary. Ended up waiting 15-20 minutes because the display wasn't giving any progress information. Then went back and tried in normal mode and the same error message just keeps coming up no matter what I try.
I want to second this post. This is EXACTLY what I saw today when trying to update 8 slot cRIO from 2011 with the v43 image. The only difference being I also got this error when trying the safemode imaging. I did try disabling the wireless radio on my laptop as some have suggested. I was able to recover the cRIO by using the 2011 imaging tool and v28 of the firmware. A couple of times I bricked it with the 2012 imaging tool and v43 and recovered with 2011 tool and v28. One other possible clue is that when the 2012 image fails I get the following sequence on cRIO status light. amber blink blink, 1 second pause, amber blink blink, etc. I am confident I installed all the labview software on my laptop correctly. USB stick, the three updates (lv, then utilities, then ds), then windriver. I tried many many times, safemode, rebooting everything...at this point i am pretty sure its not going to work.
  #38   Spotlight this post!
Unread 15-01-2012, 16:23
Have you tried imaging from a different PC?
  #39   Spotlight this post!
Unread 15-01-2012, 17:43
That's where i left off today, installing all the labview stuff on another pc. I will try it tomorrow night.
  #40   Spotlight this post!
Unread 15-01-2012, 21:28
We can ping the cRIO, but the "Communications" light on the Driver Station is not lit. We can also deploy code from LabVIEW, but we still can not enable because the Driver Station will not recognize the cRIO... Any ideas?
What computer are you using as the Driver Station? If it's the Classmate, have you reimaged it from the 2012 USB flash drive?
There was an issue a year ago with network settings sometimes getting duplicated by the Driver Station software and causing communication to get confused. If you're using a computer that still has its files from back then, it might be worth checking deeply into the "Advanced" network settings of the interfaces and making sure there aren't any extraneous IP addresses defined.
  #41   Spotlight this post!
Unread 15-01-2012, 21:34
When you say "disabling the wireless radio", what did you actually do? Just turning off the WiFi doesn't help. The way I suggest is to right-click on the relevant icon on the Network Connection control panel and select Disable from the popup menu.
  #42   Spotlight this post!
Unread 16-01-2012, 01:43
on walkabout
This issue was fixed by using a different laptop today, so it seems apparent that it was a firewall issue (even though we had checked some of the telltale signs of such a problem). The first computer was not the classmate, it was a computer with a 3 or 4 day old windows install (probably why the firewall hadn't already been configured appropriately for the driver station).
We later were trying to reimage our second cRio and got exactly the error in post 29, but after an hour so of monkeying with things (through switch, not through switch, safe mode imaging, disabled nics, etc.) it finally worked, so we're not sure what happened there. Sounds like NI is working on this one (see also http://forums.usfirst.org/showthread.php?t=18509).
  #43   Spotlight this post!
Unread 16-01-2012, 11:12
279 EMPIE's Avatar
Head Progammer
AKA: Matthew Empie
We have the image tool now but we do not have the right image.
Where do i get the right image from?
Cleveland Regional
  #44   Spotlight this post!
Unread 16-01-2012, 11:33
The image comes when you install the language specific Update from the bottom of this page:
http://www.usfirst.org/roboticsprogr...control-system
  #45   Spotlight this post!
Unread 17-01-2012, 09:22
I used another PC and everything went through fine. It probably was firewall settings on the first PC.
