Go to Post I once started to build a time machine. But then I went back in time and told myself that it wouldn't work, so I gave up on it. -dave - dlavery [more]
Unread 15-01-2012, 16:19
Re: Claw
Originally Posted by farmersvilleRob View Post
But thats still less than a usable servo, and the servo runs straight off the arm. If I was going to do an add on as well, I might as well go with a servo gearbox and output 2000 ounce inches
2000 oz-in and very, very, very slow rotation. Remember your limitation on servo power.
You need both speed and some power, so a servo probably isn't the device you want. You're saying a VEX motor doesn't have the power. Well, that leaves either a light Banebots or a small pneumatic cylinder. If you aren't otherwise using pneumatics, then the pneumatic cylinder is not going to help weightwise (because then you have to add a full system somewhere). That leaves a light Banebots motor (probably the RS395), or maybe some of the other lighter allowed motors.
Or... Wait, would a 1-inch throw electrical solenoid actuator work? How about a Denso throttle control motor? What about an AndyMark motor or gearmotor?
Unread 15-01-2012, 16:31
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Re: Claw
Could you post links to one of those 1-inch throw electrical solenoid actuators and Denso throttle control motors so I can research them?
Pneumatics is a waste for use to mount and barely use. And the bane bot motor weighs 12.4 ounces, and we need 2 for each side of the claw. That leaves barely any room for the actual parts (let alone the gearbox) because we're calculating a max weight of 3 pounds.
I guess this probably wasn't the right thing to ask because I can't provide too much information without saying our designs, but once I look at those two, I should be able to come up with a decision with the team! Thanks in advance!
Unread 15-01-2012, 17:00
FRC #4084
Re: Claw
I found both. They aren't what we need, but I think I'll stick with servos
Unread 15-01-2012, 17:02
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: Claw
Good luck then, and see you at the competitions.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
