Go to Post I would be kinda creeped out if I was one of the "famous" FIRST people. Why? Because no one is any different than anyone else in my eyes. Granted, some people stand out more, but that is because the other people might not have gotten a chance yet to shine. - Melissa Nute [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 09-01-2008, 19:02
nittemare nittemare is offline
nittemare
FRC #1516 (Grizzlies)
nittemare is an unknown quantity at this point
Solidworks KOP files
Are there any solidworks files for the Kit of Parts? cant find any
Unread 09-01-2008, 20:32
NHPilot NHPilot is offline
NHPilot is an unknown quantity at this point
Re: Solidworks KOP files
I haven't even seen a complete set of cad file for the KOP. If they are available in step or iges, you can open them directly in SolidWorks. You can then save them as part or assembly files.
Unread 09-01-2008, 21:18
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Newer versions of solidworks will convert inventor parts and assemblies to the native solidworks format. Just go File>Open and select in the file type menu "Inventor"
Unread 24-01-2008, 11:13
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
SolidWorks Kit of Parts is located at www.3dcontentcentral.com
In the Search box, enter firstrobotics (one word). There are hundreds of model files in multiple formats, SolidWorks, Pro/E, Inventor, .dwg, .dxf and 15 other file formats. You configure the part when you download. Be certain to download in the SolidWorks version you are using.
To open an existing model file in IGES, STEP or SAT format inside of SolidWorks, select File, Open. Select your file of type. Then Save.
All teams can receive SolidWorks 2007 by applying at www.solidworks.com/SponsoredDesignContest.
Unread 09-01-2011, 15:50
chris janney chris janney is offline
FRC #3266
chris janney is an unknown quantity at this point
i have a question. does anyone know where we can download the KoP for 2011 in autodesk? been hunting but no luck, any help would be appreciated
Unread 12-01-2011, 12:56
Inside of SolidWorks 2010 Design Library>SolidWorks Content>Robotics folder lives robot parts from 2010 and 2009. Ctrl select the folder to download all parts; unzip. These parts are in SolidWorks format. Many parts from 2010 are reused in 2011. We are working on the 2011 kit for parts. This link shows how to connect your parts folder to be used inside of SolidWorks - saves lots of steps in the assembly:
http://blogs.solidworks.com/teacher/...-and-more.html
At www.3Dcontentcentral.com seach
http://www.3dcontentcentral.com/part...brary/140.aspx
you can download all formats both 2d and 3d such as dwg, pro|e and inventor at previous software editions.
For SolidWorks sponsorship, go to www.SolidWorks.com/sponsoredDesignContest
For Robot Tutorials, go to
www.SolidWorks.com/Robotics
Good luck in the competition. Marie
Unread 15-01-2012, 17:08
dmulla dmulla is offline
FRC #1967
dmulla is an unknown quantity at this point
When we download solidworks .sldprt files then try to open in the 2011 student version of solid works, we get a message about 'future version' and the part refuses to open. Is there versionitis going on?
Unread 15-01-2012, 18:00
FRC #1967
Never mind. Pilot error. The 2012 vs 2011 is the Solidworks version, not the KOP version. Since we're using 2011 SolidWorks we need the 2011 part version.....
How to create 3D dxf files in Solidworks, Inventor, or other? Travis Covington SolidWorks 6 03-05-2006 21:46
Solidworks Files Panther378 Technical Discussion 1 21-01-2006 22:34
virtual KOP in solidworks gondorf SolidWorks 1 20-01-2006 01:34
KOP Chassis & Transmission Inventor 8 Files JVN Inventor 0 12-01-2005 15:00
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
