Go to Post water electricity=bad - Chuck Glick [more]
Unread 15-01-2012, 17:26
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Laptop will not find the robots cRIO
What are you using to 'scan' for it? Are you using the crossover cable?
Unread 16-01-2012, 20:02
Mr.Trips Mr.Trips is offline
FRC #3179
Mr.Trips is an unknown quantity at this point
We are waiting for our new cRio to come in but would like to use the old robot for some trial runs. So would this be the problem that the new software will not work with the old crio and power distribution board.
Unread 17-01-2012, 08:04
The HW will work fine once it is imaged to be compatible with the newer programming and communications tools. If you later want to put it back on the old robot, you can decide whether to keep the newer image or put back the older image.
To image it, use the cRIO Imaging tool located in the Tools menu.
Greg McKaskle
