Re: Range Finder Help
The Motor Set vi uses a range of -1 (full reverse) to +1 (full forward). Transform the Analog Voltage Get vi result to turn distance (0.01 volts per inch) into whatever power you want to run the motor at. You'll probably want something a little fancier than a simple multiplication -- a basic lookup table where input is distance and output is power should be about right.
