Go to Post Lexan $20.... Stock Aluminum $30.... Having a OI that is heavier than the robot PRICELESS.... - GBIT [more]
Unread 15-01-2012, 17:55
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Gearing for mecanum
I have attempted to calculate the necessary gearing ratio for a mecanum drivetrain. The drivetrain will have 1 CIM per wheel (and no other wheels), and use 8-inch Andymark mecanums.
I calculated the gear ratio so as to be traction-limited under the following assumptions:
  • 150 pounds max robot weight
  • 0.7 max CoF for the wheels (reported by Andymark)
  • 40 amps max continuous current per motor
I came up with a desired ratio of about 16.25:1. This results in a theoretical free speed of 10 ft/s.
Last year's robot used a kit frame. This had about an 8:1 gear ratio. Since this computes about double the required gear ratio for (theoretically) slicker wheels, I am skeptical of my results.
Does this seem correct?
Unread 15-01-2012, 17:59
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: Gearing for mecanum
I don't know much about ratio however,
[R03]
The Robot weight may not exceed 120 lbs. When determining weight, the basic Robot structure and all elements of all additional Mechanisms that might be used in different configurations of the Robot shall be weighed together.
This excludes bumpers.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 15-01-2012, 18:02
Taken care of. Note that the ratio was calculated for 150 lbs (robot+bumpers+battery).
AKA Ryan Van Why
FRC #0957 (SWARM)
... and batteries.
I used 150 pounds so I had a bit of a margin for error.
Unread 15-01-2012, 18:04
JosephC's Avatar
I figured that was the case, but I wasn't sure.
Referee: 2015 - ?
Unread 15-01-2012, 18:41
dtengineering's Avatar
AKA: Jason Brett
We used stock 12:1 banebots planetaries with CIMs and 8" AM Mecanums several years ago and were relatively pleased with their performance.
I don't remember having wheel slip aside from when one of the wheels was off the ground, and we did get in some pushing matches... so I can say that a 12:1 ratio does not exceed the ability of an AM mecanum to put torque to the ground.
Going to a slower, higher torque gearbox, like the 16:1 may have advantages in that a higher torque output can allow for greater acelleration and better low-speed handling.
But I think I'd stay away from the 8:1 ratio... that seems very "fast" to me. Although it is common to calculate for a a robot's top speed, if you watch the game closely teams spend very little time at top speed, and a lot of time maneuvering, acellerating and decellerating.
Jason
Unread 15-01-2012, 18:43
AKA Ryan Van Why
FRC #0957 (SWARM)
Okay, that helps clear things up.
I think that in our case, we want to be traction-limited more than fast. Therefore, I'll let the team know that we need a 16.25:1 ratio.
Thank you.
Unread 16-02-2012, 10:55
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
If you used 9:1 for 8" wheels, would you expect to see CIMs cut out at initial full acceleration? Not that I have any reason to ask :-)
Unread 16-02-2012, 11:05
pfreivald's Avatar
AKA: Patrick Freivald
We've used 9:1 on Andymark 6" HD mecanum for several years and are very happy with the results... That is at least close to a 12:1 on 8" wheels.
I'm not sure I'd want 8:1 on 8" wheels!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 16-02-2012, 11:07
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Last year we used the mecanum wheels directly out of AndyMark nanotube. The gearing on that was 12.75:1. We were pleased with the results.
Hi!
Unread 16-02-2012, 11:40
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
We use the AndyMark nano transmissions but swapped gears to get 10.67 for 6" wheels - it works great. We figured quickness was paramount for this years game since the hump and bridges won't allow for full court sprints.
HTH
