Go to Post We're all human, we all make mistakes. How you deal with mistakes and problems, is what really elevates successful people, robotics teams, organizations, etc. above the rest. - artdutra04 [more]
Unread 15-01-2012, 19:30
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Best type of screw/bolt
Originally Posted by aheg1220 View Post
The type of screw doesn't matter as much as the quality of the screw.
Certain types of screw drives/heads are more appropriate depending on application, and some are more prone to stripping than others are, regardless of quality.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 16-01-2012, 01:09
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Originally Posted by Tristan Lall View Post
Supply and cost issues factor into this as well. If you're in the market for relatively inexpensive screws, and located in Canada, Robertson parts and tools are easy to find (in wood and machine screws). If you're not, you're stuck with the thoroughly inferior Phillips.1
[/size]
I was going to suggest Robertson as well, but decided not to since I have never had the privilege to use them myself. All that I know is that after using Phillips for my entire life, I was thoroughly jealous when I first read a description of Robertson screws. Ford liked them to, he considered using them on his production lines to improve efficiency but couldn't due to their limited availability in the US.
Unread 16-01-2012, 01:18
AKA: Alan Wells
FRC #1350 (Rambots)
Originally Posted by 372 lives on View Post
my team buys custom "security" bolts with the bat signal on the head never had one strip yet
You wouldn't be referring to clutch head bolts, would you?
Unread 16-01-2012, 01:53
aheg1220 aheg1220 is offline
FRC #0599
aheg1220 is on a distinguished road
I completely agree. But you can't forget that a screw or bolt of poor quality is more likely to strip out than a screw of good quality. Basically, the universal rule of "you get what you pay for" applies here. I would much rather spend a couple more bucks on a box of USA made alloy steel or grade 8 bolts than a box of no-name junk made from unhardened steel.
Unread 16-01-2012, 20:30
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
At Team 3489 we need to keep this bolt chart handy:
Unread 16-01-2012, 20:44
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
if i were involved with a team activly i'd use that as a shop poster. I may make it into a poster anyway, it is too funny!
