Go to Post There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". - Jeff Pahl [more]
Unread 14-01-2012, 18:14
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
How Slippery is the Bridge
I am trying to figure out how slippery is the bridge for the 2012 FRC game. I think the specs are saying that the field bridge material will be HDPE. I found the coefficient for that to be .28. That seems quite slick.
The YouTube video show a battery not sliding?
Am I on the right track?
Anyone know for sure?
Thanks ahead!
Unread 14-01-2012, 18:21
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: How Slippery is the Bridge
HDPE is a slick material. You are correct. You have the COF number, now compare that number with some other material you are familiar with if you don't have access to a piece of HDPE & you'll get an idea of just how slick.
Unread 14-01-2012, 18:24
The bridge surface is polycarbonate. HDPE is the material for the bridge "deck" which is below the polycarb surface.
Unread 14-01-2012, 19:46
DonRotolo's Avatar
Back to humble
FRC #0832
That is correct. The surface is polycarbonate.
Unread 14-01-2012, 19:56
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
Would that be comparable to the Lunacy surface?
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Sooooo, how slick is polycarbonate?
Every day is a new adventure!!!
Unread 14-01-2012, 20:00
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
According to Wikipedia, the CoF of polycarb is 0.31
To compare with wood, according to this,
Coefficients of sliding friction for smooth, dry wood against
hard, smooth surfaces commonly range from 0.3 to 0.5; at
intermediate moisture content, 0.5 to 0.7; and near fiber
saturation, 0.7 to 0.9.
Unread 14-01-2012, 20:05
the man's Avatar
AKA: Jacob Overla
FRC #4004
How much does the coefficient of friction change with wheel composition?
Unread 14-01-2012, 20:16
djdaugherty djdaugherty is offline
Mrs. D.
FRC #2053 (TigerTronics)
djdaugherty is on a distinguished road
There is no such thing as a coefficient of friction for one material (e.g. polycarbonate). A coefficient of friction is always between two materials (e.g. polycarbonate and rubber or polycarbonate and wood). You will find many examples of CoF between materials because they vary greatly depending upon the composition of the two materials. The CoF values are determined emperically. Your best bet is to purchase a sheet of polycarbonate and play with it.
Unread 14-01-2012, 20:58
the man's Avatar
AKA: Jacob Overla
FRC #4004
So in other words, Posting the coefficient of friction gives no help at all because it various between materials. We need to experiment. Good thing our mentor has about 20 sheets of 1/8 in polycarbonate lying around. mwahahah.
Unread 14-01-2012, 22:33
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Make sure you remove the masking material, if there is any. If you leave that on, your results will be inaccurate.
Unread 14-01-2012, 23:35
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
What? And get scratches on it? Won't that change the CoF too? You mean Cof will be different in Elims than it was in Quals? week2 differs from week1? Week 6 balancers will have a cake walk on the scratch-covered bridges. Or do you think we'll get fresh polycarb each tournament?
All hail the goddess of uncertainty! I mean, I would if I knew in which direction to genuflect.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 15-01-2012, 12:22
maxwellt's Avatar
maxwellt maxwellt is offline
what time is it? 540!!!
AKA: Tim Maxwell
FRC #0540 (Talon 540)
maxwellt is an unknown quantity at this point
if your wondering you are pretty much driving on a white board for the ramps which is really slick depending on the wheels you are using for this year, if you use the wheels from the KOP you have no problem on the bridge but if you use mechanum wheels you will be sliding all over the place on the ramp during the game
winning does not= trophies
winning = learning
FRC team 540's 2011 moto
Unread 15-01-2012, 13:51
the man's Avatar
AKA: Jacob Overla
FRC #4004
I dont think so. The mechanum wheels are a soft-ish rubber I think they will grip quite well, I also saw a youtube video of some one going up a bridge with mechanums.
Unread 15-01-2012, 19:35
Samk Samk is offline
Lead Builder
FRC #0619
Samk will become famous soon enough
We had some hdpe laying around the shop, took one of the wheelchair wheels to it, the wheel stuck surprisingly well.
