Go to Post The most important piece of advice I can give is have someone assigned to pay attention to the batteries. You cannot imagine how many teams end up saying "I thought you were charging the batteries..." - RoboMom [more]
Unread 15-01-2012, 17:46
computerish computerish is offline
FRC #0619
computerish is an unknown quantity at this point
Legality of modifying the Jaguar cases
Is it legal to drill holes to enlarge the mounting holes on Jaguars? We couldn't find anything saying we couldn't but we wanted to check.
Thanks!
Unread 15-01-2012, 17:50
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Legality of modifying the Jaguar cases
I think [R58] prevents this:
Originally Posted by R58
The control system is designed to allow wireless control of the Robots. The Driver Station software,
FirstTouch I/O module, cRIO, speed controllers, relay modules, wireless bridge, and batteries shall
not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting,
machining
, gluing, rewiring, disassembling, etc.), with the following exceptions...
Kettering Motorsports
Unread 15-01-2012, 20:50
bmxer51 bmxer51 is offline
FRC #2874
bmxer51 is an unknown quantity at this point
Just Velcro them all down. Its way easier to switch them out when they catch on fire which is inevitable by the jags... We cover the entire electronics board on Velcro so we can move them around as needed.
Unread 15-01-2012, 20:57
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Some thing to remember is to not remove the screws for attaching the motor and battery leads all the way. That will cause them to burn up.
Every day is a new adventure!!!
Unread 15-01-2012, 21:07
FRC #2874
How else are you supposed to attach the circle connectors to them?
Unread 15-01-2012, 21:08
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Er, exactly why would you need to enlarge the mounting holes?
Academic Student (Forever)
Unread 15-01-2012, 21:15
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Why do you say this?
Unread 15-01-2012, 21:16
That is only true for the old (tan) jaguars. This can be seen in the Jaguar FAQ (in the answer to question 1).
For the tan jaguars, use a fork connector. If you do remove the screws to use ring terminals, carefully vacuum out any debris.
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
You aren't meant to use ring lugs (the circle connectors) on the tan Jaguars. I regret this, as ring lugs are excellent for high vibration applications, but the design of the prevents it. The tan Jaguars use a color-coded "captive screw" arrangement in which the screws are not supposed to be fully removable to prevent mixing up the color code. Successfully removing the screws causes the release of small metal fragments from the hidden part that is supposed to hold them in, which can get into the innards of the Jaguar and release the magic smoke.
The correct lug is a "spade" lug, which has an end shaped like a U. You loosen the screw slightly and slide the metal tabs underneath, then tighten vigorously.
ETA: I am happy to know that the black jags will permit ring lugs. Thanks, Joe.
Last edited by vhcook : 15-01-2012 at 21:19. Reason: I just learned something new.
Unread 15-01-2012, 21:20
the man's Avatar
AKA: Jacob Overla
FRC #4004
I still dont trust um.
Unread 15-01-2012, 21:22
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
This was true with the brown jags from the first year we had them - they were made with captive screws, and removing them entirely could result in small metal shavings being removed from the screws (and thus cause internal shorts that could cause problems). However, the black jags do NOT have captive screws, and they can be safely removed without any worry.
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
The tan Jags had this recommendation in the documentation. The screws were not supposed to be unscrewed all the way, by design. The concern was that if the screws were removed all the way metal shavings would be dropped inside the controllers case.
This is no longer a concern with the Black Jaguars, the screws can be removed completely without issue.
http://team2168.org
Unread 18-01-2012, 07:46
Thanks!
By now you have determined that it is a violation of the rules to do so. I would recommend that you disassemble a failed Jag and peer inside to see what might have occurred if you enlarged the holes before asking. It is always fun to take things apart.
