Go to Post There's "FIRST the organization" and then there's "FIRST the vision for the future through a set of ideals". I've grown somewhat skeptical of the former in recent years, but, after 10 years, I'd still throw myself in front of a bus for the latter. - Rich Kressly [more]
Unread 13-01-2012, 18:00
swapnil94 swapnil94 is offline
FRC #2935
swapnil94 is an unknown quantity at this point
c++ programming
All the tutorials I found on the internet shows how to build a program, deploy program etc. from Windriver. But none of them shows syntax to do certain function. Like for example, RobotC used for programming vex robot had list of all the available classes and proper syntax example showing how to use them. I can't find anything like that for Windriver C++ classes supported by WPILib. Are those few examples available in windriver the only way to view proper syntax of those class? Thanks
Unread 13-01-2012, 18:09
Re: c++ programming
I don't think it's exactly what you are looking for but the "WPILib C++ Reference.chm" help file at C:\Windriver\docs\extensions\frc may help.(I hope that's right, it's from memory, the computer I'm on doesn't have Wind River)
Unread 14-01-2012, 01:20
scottbot95 scottbot95 is offline
FRC #1388 (Eagle Robotics)
scottbot95 is an unknown quantity at this point
Re: c++ programming
Also, if you look at the *.cpp files in the zip file under C:\WindRiver\WPILib there is comments on all the functions that describe how they work and what they do.
Unread 15-01-2012, 22:36
FRC #2935
Re: c++ programming
Thanks! I was looking for that.
