Go to Post However, it is logistically impossible, so it's now just a joke. - EricH [more]
Unread 14-01-2012, 09:54
Kpown Kpown is offline
FRC #1123
Kpown is an unknown quantity at this point
Question Why even Go with the kinect?
Join My Minecraft Server:
Hamanchi:
zahillacraft
123
SERVERIP:
5.120.151.126
Play Aiimscape
Aiimscapes(DOT)smfnew(DOT)com
mediafire(DOT)com/?hfixy3uon1da3z3
GO TEAM 1123!
Unread 14-01-2012, 10:05
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Why even Go with the kinect?
You may be interested in this thread, about running the Kinect on the robot.
Unread 14-01-2012, 10:31
Keep in mind that only one robot per alliance gets to use the Kinect anyway. I hope that all teams build an autonomous routine that tries to score.
The benefit of the Kinect is to take advantage of driver input and deal with unexpected field conditions. It isn't uncommon for robots to get in the way, balls to get in the way, or a field bump or other unexpected issue introduces a problem that the relatively limited auto's don't compensate for. Drivers excel at this situation -- presumably even when driving by waving their arms like a scarecrow.
Greg McKaskle
Unread 14-01-2012, 10:34
Djinn74's Avatar
Djinn74 Djinn74 is offline
C++ Ninja in training
AKA: Henry Braeske
FRC #3397 (Robolions)
Djinn74 is an unknown quantity at this point
(sorry about the redundancy, started posting before second post was added).
I suppose that adaptability is the main reason.
If another team has autonomous code to just shoot until it runs out of balls, then you can feed them balls (per the game animation).
Plus it may help to be able to move around the other robots on your alliance without having to alter all of your autonomous code before the match.
Seems rather complicated. Whether its worth it or not I cant really say.
"Its totally going to be a water game!!"
"Bet you $10 that it isn't.
"Yeah... not making that bet."
Unread 14-01-2012, 10:39
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
My guess is that our team will have an autonomous that stays where it is and shoots 2 balls, and our kinect strategy would be to dump balls on the bridges onto our side of the field. Although, it's entirely possible we could write an autonomous that dumps balls as well.
I think the main "reason" to use the kinect is that drivers are presumably better than sensors, you can make strategy changes on the fly, and it's easy to set up (or so I've heard)
Unread 15-01-2012, 22:56
Nerfighter1629's Avatar
Nerfighter1629 Nerfighter1629 is offline
Carpe diem
AKA: Becca Lee
FRC #1629 (GaCo (Garrett Coalition))
Nerfighter1629 is an unknown quantity at this point
Instead of viewing it as a control method, we view it as a start/stop mechanism. Last year in autonomous, we had many problems with field calibration that lead to a couple big penalties from putting an ubertube in an opposing feeding lane. The way I look at it, the Kinect is a way to avoid that. You can program a simple command to realign the robot a tad to save the hybrid mode
Unread 15-01-2012, 23:05
darkMatt3r darkMatt3r is offline
Brah Everyday
AKA: Matt Pearring
FRC #1378 (Hilo Viking Robotics)
Team Role: Driver
darkMatt3r is an unknown quantity at this point
To be honest, incorporating the kinect into our program will probably only happen in two ways:
1. Attach it to the robot to do some kind of vision tracking.
2. Use it to see an epic pose made by our human player so it starts the program.
I don't think we're going to bank on using the kinect and i really don't tink we're going to be using more than one motion if we go with the kinect.
Unread 15-01-2012, 23:07
Andrew Lawrence
Posts: n/a
Taken from another Kinect thread: http://www.chiefdelphi.com/forums/sh...2&postcount=12
