Go to Post I guess that some people don't understand that no means no. - Steve W [more]
Unread 15-01-2012, 21:28
Slothbron's Avatar
Slothbron Slothbron is offline
AKA: Nathan
FRC #3216 (Missoula Robotics Team)
Slothbron is an unknown quantity at this point
Conveyor Belt
So my team is think about a conveyor belt system to pick up the game balls with. We are wondering what would be the best material to use for the belt. Or if it should be a series of smaller bands.
MRT 3216
2010- Salt lake City Highest Rookie Team seed
Unread 15-01-2012, 21:29
Andrew Lawrence
Posts: n/a
Re: Conveyor Belt
Polycord. 'Nuff said.
Unread 15-01-2012, 21:33
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: Conveyor Belt
We've always used 1' polycord for our conveyors, as it can be lighter. We have a few tread based designs lying around the shop that we never actually wanted to use.
If you really want to know about the tread then I can go find out, but I recommend using polycord like this... http://www.chiefdelphi.com/media/img...373a11c3_l.jpg
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 15-01-2012, 21:52
Cem8301's Avatar
Cem8301 Cem8301 is offline
Carolyn
AKA: student president
FRC #3413 (Mad Cows)
Cem8301 is an unknown quantity at this point
Re: Conveyor Belt
Polycord is a good choice!
@JosephC, what did you use as the polycord track? (in other words, what is the black thing called?)
The steaks are high. Prepare for udder destruction!! <3 Mad 3:O's
Unread 15-01-2012, 22:18
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Conveyor Belt
A belt is very, very difficult to get to work well. It has a tendency to "walk" to the side. In professional belting, they do two things to prevent this - First, the framing and rollers are kept perfectly square, and second, the roller is made angled, so the center has a larger diameter than the sides. This way, a correctly made belt will "walk" towards the center, instead of the sides.
On a robot, keeping everything perfectly square is very difficult - virtually impossible, when you consider the hits and movements you get on a robot.
So, to get around that, a lot of teams use the "polycord" stuff. The setup is almost exactly like a normal conveyor belt. You use normal straight rollers, have multiple cords, and have to have some way to keep them straight - groves in the roller might work, or a "comb" stuck between the cords.
Unread 15-01-2012, 22:45
Slothbron's Avatar
AKA: Nathan
Re: Conveyor Belt
So where is the best place to get this polycord stuff at. Also are you able to just buy rollers for them or do you have to make them.
MRT 3216
Unread 15-01-2012, 22:54
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Re: Conveyor Belt
We used poly cards before and were not impressed, maybe we did not use them right. We have been experimenting with belt, so far so good....
http://www.youtube.com/watch?feature...&v=q0ZJV0i7fm0
Faridodin "Fredi" Lajvardi KD7WKD
Unread 15-01-2012, 23:08
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Conveyor Belt
http://www.mcmaster.com/#urethane-round-belts/=ftozzw
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 18-01-2012, 00:44
ColdRail ColdRail is offline
FRC #4061
ColdRail is an unknown quantity at this point
Re: Conveyor Belt
What diameter do you recommend for the Poly Cord and what are you using for pulleys?
Unread 18-01-2012, 01:35
JosephC's Avatar
Re: Conveyor Belt
Im not completely sure what the black roller is in that picture (as its not our robot, its just a picture I found after a quick Google search).
In lunacy I believed we used PVC rollers (not 100% sure, I'll double check tomorrow) much like the ones used in that picture. 2nd place on Einstein; won IRI(if anyone doubts the power of polycord).
Referee: 2015 - ?
Unread 18-01-2012, 03:49
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: Conveyor Belt
My team has used polycord many times over the years with plenty of success. We first used it in ZoneZeal, but we used 1" wide flat belting material that was melted together. In Aim High, we used 1/4" round solid core, also melted together. It was a bear to melt together all the pieces but it worked wonderfully. After that year we discovered hollow core belting, which is much easier to work with and yields the same result, never had a belt snap.
aaaaaaaaaand this is where I'm probably going to get either a slap or a hand shake from everyone reading, this is a very polarizing design...
In Lunacy, my senior year, we had the brilliant idea to combine the flat belting and the solid core tubing... by melting them together. This design was then fed through the gap in 80-20, and we got a... brush. Behold, our robot from 2009.
...yeah, we did that. And it was awesome.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
