Go to Post An extra week of driving practice and shakedown outweighs a lot of ooo-shiny. - Billfred [more]
Unread 15-01-2012, 23:32
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: 3 robots designs I hope to see this season
Originally Posted by farmersvilleRob View Post
3000 watts, but that's combined. You can't mismatch motors and think there will not be binding (for arm robots) or miss matched speeds and spin up times (pitching machine). Also that battery would drain so fast! lol
You can use a different power motors in the same mechanism easily without any problems, as long as you match the free speed to within a few percent of each other. For example, if Motor A is 10,000 rpm and motor B is 5,000 rpm and you want to use them in the same gearbox, simply gear down Motor A 2:1 before you interface it with Motor B.
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-01-2012, 23:35
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
But if you geared down one motor, when applying the ball to the system, one motor has more torque that gives more resistance to the ball's inertia. But at the same time, the other motor takes the same resistance to the ball's inertia, but has less torque than the geared down motor so it slows down more and gives the ball an odd trajectory and speed and backspin.
Unread 16-01-2012, 00:20
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
FALSE.
If you mix two motors in a given system, and gear them appropriately, they will share the load.
Why?
Say I have a CIM (free speed say 5000rpm for this simplified example, with a torque of 1 units) and a FP (free speed say 20000rpm for this simplified example, with a torque of 0.2 units)
I gear the FP down 4:1 before mixing it with the CIM. The free speeds now match, but the FP only has an equiv. torque of 0.8 - the sum of the stall torques of the two motors geared together is now 1.8 units
When I apply a load to this system, the motors will slow down because there is a load. Say I apply a torque of 0.9 - half of our stall 1.8. Assuming everything is perfectly linear, the motors will slow down to half speed. Because they are geared together, they HAVE TO RUN AT THE SAME (relative) SPEED. Since, at a given speed, each contributes a different amount of power, the power they contribute is approximately correct, the sum of their power output is equal to the load, and given the power output of the motors, the larger motors will contribute more power than the smaller motors. - In this example, the CIM would contribute 0.5 torque units and the FP would contribute 0.4 after gearing (the FP sees 0.1).
You can effectively gear motors relative to one another and add their (geared) torques without much issue, and design the system as if it was a single super motor. To make things even better, most of the motors in the KOP come in pairs, and you can have up to 4 CIM or BB's, so you don't often need to mix motors of different types.
(as a side note, BJC and I wrote up some TI-84 equations/graphs for throwing a ball, and it wasn't as bad as you make it sound, balancing the ramp isn't very hard for a single human-driven robot, and if you are ever in the opposing alley it's a penalty under [G28], even if you were collecting balls)
Kettering Motorsports
Unread 16-01-2012, 00:31
Palardy, I don't see anything in [G28] that bars entry to the Key or Alley (Bridge is covered elsewhere).
[G28]
Robots may not touch an opponent Robot in contact with its Key, Alley, or Bridge.
Violation: Foul; Technical-Foul for purposeful, consequential contact.
And neither does the GDC:
Game - The Game » Robot-Robot Interaction » G28
Q. Can a robot (that is not in violation of G28) touch or enter the key or alley of the other alliance?
A. Yes
