Go to Post ...last year's watchdog had a litter of watchpuppies. - EricVanWyk [more]
Unread 15-01-2012, 23:35
Re: Range Finder Help
The "Interpolate 1D" vi is an easy way to implement a lookup table. Provide it with two arrays, one of input values and one of the assocated output values. See the "1D Interpolation.vi" LabVIEW example to play with how it works.
Unread 16-01-2012, 11:46
DonRotolo's Avatar
Back to humble
FRC #0832
Or, more simply:
You experiment, and find that at a distance of (0.73 volts = 73 inches), setting your motor control to +0.48 makes the shot 9 out of 10 times. You also find that at 1.45 V (145") a motor control of +0.83 is 'perfect'.
You create a table:
Measured  Motor
Distance  Voltage
73         +0.48
145        +0.83
This is a "look up table".
With such a table, you might be able to assume that a distance halfway between 73 and 145 (=110) should use a motor control of halfway between 0.48 and 0.83 (=0.65). Doing this kind of math to 'guess' at what might be a good value in between known-good values is called "interpolation".
Or, you can just experiment every 12 " and see what you get, and use the value in the table that's closes to the measured distance.
Be sure to take into consideration what to do if there's a robot between you and the spot you want to measure from.
