Go to Post The more time we spend there, and the more investment we have in the team, the more rewarding it is. - ILAMtitan [more]
Unread 16-01-2012, 00:53
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Re: Java image processing - accessing pixel data
Originally Posted by davidthefat View Post
It is possible to do it. The Image class has a pointer to the jpeg image in memory named "Image". It is a public field and did not catch that it was there the first 2 years. You just decode that data into raw bytes and then you can access as you want to as "pixels".
This is far, far easier said than done. A jpeg image is by its nature compressed. To access the data, you would need to decompress it, which would take a very long time to do. Instead of only accessing the pixels you need, you would have to access all of them. You can read a little more about it here
https://en.wikipedia.org/wiki/JPEG
Unread 16-01-2012, 18:21
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
And that is what I was going with. It is not as easy as it sounds.
Unread 17-01-2012, 00:14
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
If all you can access is the compressed image, then no. You can not access the image data. I ported a JPEG decoder to the cRIO last year, and it did not go well (it worked, but very slowly). I used to think it might work better if done in C++, but now that I know the cRIO has an onboard FPGA, I would bet that it does the decoding.
Unread 17-01-2012, 15:43
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
It's worth mentioning that we've found that calling certain NI C/C++ functions from Java is very slow. I find it surprising that it hasn't yet been mentioned that the image classes, namely BinaryImage has a very useful set of methods beyond finding ellipses - the particle report methods. Each "blob" in a binary image is considered a particle, and the particle report allows you to access important properties of each particle, like its position, size, number of pixels in the particle, etc.
while(!going.isTough());
tough.exit();
What will we do tonight, Warfa?
The same thing we do every night, Patrick. Sit and wait for Electrical.
Unread 17-01-2012, 19:26
The jpeg decoder on the cRIO is part of IMAQ. It is pretty standard consortium code and does not run on the FPGA, but runs on theFreescale processor.
Greg Mckaskle
Unread 17-01-2012, 22:57
FRC #1700
Which functions in particular are you having slow results from? I got slow results from the getOrderedParticleAnalysisReports, but the slowdown was on the java end.
Unread 17-01-2012, 23:04
I tossed together a quick sample that retrieved the image from the camera, did a threshold, a convex hull operation, and got the particles, and sorted them by area. The first three of those were done with the BlockingFunction protoyped methods. The whole operation was clocking in at around 400ms with nothing else running on the robot.
tough.exit();
Unread 18-01-2012, 08:32
What size image was this, and did it include decoding the image?
Greg McKaskle
